gnubler
Bunch of images below. Working on a bid for this project and would like some suggestions on how you would make and install this sign. Two faces measuring 84x48" into existing framework projecting from the side of a building, with an awning below so boom lift is required for access. Was able to snag old Google street view shots of the old sign that used to be there so you can kinda see what they did. One of the faces is still there in the basement of the business, it was made of 3mm ACM and I can use it as a template if needed. What materials would you use to make this and what would be the easiest method of installation? We haven't been up there yet to measure the brackets and see if they're bolted in or welded. For reference the bottom of the frame is about 17 ft from the ground. Thanks in advance!
