installing stripes to a 45ft trailer
DrunknMonk
Hi all im apply graphics to a 45ft trailer, the design has 20mm stripes the full length, I have to fit these in 2.5m sections, the problem is when I'm measuring and putting a chinagraph pencil mark say every half meter, the lines dip up and down, so when you look down the side of the trailer they dont look right, but from the side and 20ft away it looks fine, I just want to get these correct as ive got 10 trailers to do, i thought about using masking tape as a guide, but im working on my own and its hard to fit the making tape, any help would be appreciated :) also a quick one im fitting the graphics in a garage which is only 10c and the trailer is full of rivets, will this still be ok customer not looking for any guarantees .
Thanks Gary
eahicks
Chalkline, yes.
Billct2
Don't go over the chalk. Or if you that concerned use the chalk line to apply a masking tape straight line, then wipe off the chalk and pally the stripe.
DrunknMonk
laser level sounds good, just so I can buy some more toys :) but would have mod it the trailers are aluminium so might have to put a suction cup on it unless there are ones available
phototec
I use a rotating self leveling laser level mounted on a tripod about 10' away from the trailer, the laser can be set to pan left to right projection the red line on the trailer. After adjusting the laser height on the tripod it makes it easy and no cost of tape or marking pencils.
It is one of my best investments, use it all the time on almost any sign project.
