Just screwing around....
Joseph Dunkle
I was just killing some time waiting to go to lunch and started playing with Corel and came up with this. It is a little I guess a modern industrial type logo. I have not really designed a logo, I was using Vladimir Script on my business cards and invoices.
Shovelhead
I'll be the a-hole here.....boring.........
no offense.....it doesn't convey design ability to your customers.
Again, some here are too afraid to give constructive criticism.
Rick
I'm a hole too, I also think it's a little boring.....
It is easy to read I'll give you that.
There are some kerning/tracking issues...especially the "e" on "here" The typeface on "here" is a little porky too.
On a side note, modern industrial is such a wide description. In my limited knowledge I take that to mean 1910-1930's industrial. I happened to google that term and the images varies from 50's modern to current modern and most of it was in architectural references. Industrial has a wide description, then modern gets messy with the Pre-modern, modern, late modern and post modern (the era we are in now)...I get confused by all of it and I have hundreds of books on the subject.
2NinerNiner2
Dear Bill,
I don't care if you ARE the richest man in the world, umpteen years running ... it's still "boring" ? :)
Techman
who cares about boring?.
Will it work? Probably.
Is it easily read? Yes
Would I use it? probably
Will it be remembered? yes
So who cares about boring, or kerning..
sullosau
look at Dell, most gas stations, some of the most BORING logos and brand names around, nike swoosh, no imagination or anything, sure to a design pro they might say zzzzzzzzzzzz boring but its remembered.
Less is more!
4am here Ill be quiet now
Joseph Dunkle
A-Hole-ism is not a bad thing. The here is in bold. I revised it to just regular.
See attachment
jimdes
I like the simplicity but . . .
Complete the background panels similar to this sample and:
1. Your logo will always carry your specified colors and not be subject to changing backgrounds.
2. It will keep the number of colors to two making reproduction less expensive and make it easier on the eyes and quicker to identify (not my colors).
3. solid background panels will give the logo it's own "space"
This sample is just to explain what I can't put in words . . . not a finished product by any means.
Joseph Dunkle
I understand what you are saying about the background, my pickup is green but my new van is gonna be white and your fleet needs to be a uniform color IMO.
iSign
I thought he was "just screwing around"
...you mean this is your logo you are designing for real??
Geary
Yes, Joe, I like it just fine. If you don't like it later on....big deal....rip it off. Do it over. It's only vinyl, right?
My input:
Using the first idea.....go a bit smaller on "here" (as someone else suggested). Use the font "Impact" for "SIGNS & BANNERS" and make it fit exactly under the word "here"....exactly end to end.....not close as it is now. "All caps" fill out space better as the subordinate copy under a header. As Mike Stevens used to say...the "silhouette" it creates makes it less competitive graphically.
~gear
