Logo Advice/Opinions
dhamlett15
Just wanted to post and get some opinions or advice.
Dustin
Rick
Too busy, and not very legible, Stacking graphic elements usually causes legability problems, you are compounding it by adding the outlines.
Not a big fan of prismatic letters, I would try a simpler typeface and add a subtlle dimensional element to it.
By the way, what kind of client are you trying to attract and have you seen logos you admire a lot?
Deaton Design
I think you have a good start Dustin. Just needs a little more tweaking, or a little more pizazz. I used the same font you did on the name, but changed the script to another style, which is Speedway, so its still one of Steves fonts, which by the way are great fonts.:)
I beefed up the outline around all the lettering, added a 15degree shear, a straight panel as the wiggly one was competing with the lettering, and a large round graphic behind the lettering. I then added a drop shade and made sure where it covered the panels it was a deeper color than the panels. This was easily done in illustrator with the knife tool. Just some suggestions for you, and keep at it, you're on the way. :)
iSign
Nice job John.
I can't help wondering if that same layout could work with "Hamlett" in script, on top... & "SIGNS & GRAPHICS" on the bottom in bold prismatic caps?
...and even though I tend to think it might be better that way, if it does work... I'm also curious what others think of these 2 choices. (in general, not just in this layout)
As Rick says, too much going on. When it comes to names, I am a big fan of simplicity. Simplicity is legible, which in turn becomes easily remembered. Even though you are in the racing game, there is no rule that states that you must use flags, flames, multiple colors etc.
Below, although fuzzy, is something simple but with greatly contrasting colors, and easily interchanges with either of your ventures.
iSign
dude... with all due respect... you've got to be kidding posting that!
Legible? YES... but that's absolutely all it is. we're not putting his name on a shipping crate so the forklift guy can find it... this guy wants a logo!
dhamlett15
Here is another stab at it. Thanks for the advice everyone. John always like your style of work. Let me know what you think of these.
Respectfully Doug, I disagree. What was put up wasn't to say this is "it". It is to exaggerate the point that I do not believe that a logo requires 50 different colors, coupled with all sorts of effects and distortions.
John's work, as always, is fantastic! At the same time it is more of a sign, or something that you would use on a vehicle, even a business card, but not letterhead.
Deaton Design
I dont take that as a stab at my work pro, I understand what you mean.
Sometimes less is better, but in the way of a signshop or sign design business, I really dont think you can have enough as far as the design goes.
People respond better, or at least I think, to something that really jumps out at them (without knocking them out) and something that shows the high end of what you can do.
My point is probably better illustrated by one of the best logo designers out there, Dan Antonelli.
Check out his designs here:
http://www.graphicd-signs.com/html/small_business.htm
It was never intended as a slam - no way in hell (and please, I do not want anybody else to think that either).
This is going away from the intended purpose of the thread but we what we are actually speaking about are fundemental differences of business practices. Even Mr.Dan's points are well taken, and understood.
You see too much glitz, even in the sign business can keep people away. The best reputation, and money, will come from work performed for clients and their referrals. I was taught this by some of the most succesful sign people here in the area. The biggest guys have nothing that comes close for their identity. (These are the guys that are running around with a million dollars in equipment, and their 30k printers are toys :))
Anyway, my point is that it is best to aim for simple and professional, with the ability to "cross" over, if needed.
Another point, even in racing, if we were approached for sponsorship by a team (I am talking serious sponsorship - not milkshakes) and we were presented with a proposal with the original logo - we would probably feel that the team was not as serious.
Again, this has absolutely nothing to do with your illustration - you are one of the best!
This has been said many many times from every angle known to sign makers. Your own logo is the hardest one to develop. First of all, you want to use every trick in the book, pull out every stop and let all the balloons go in one fell swoop. After you display it, you let all the pigeons loose and hope they don’t drop on it.
When ever designing your own stuff, you just never know when to quit. Put a little gold here, some engine turn there, some bright colors over here and some neat fades over that little corner and when you get your nose off the paper [or away from the screen]…. you say…. HOLY F***…. I can do better than this. And you start all over again, making all the same mistakes going in the opposite direction.
Is there no end to this madness ??? Yep, get a few ‘Old Mills’ [my answer to everything] and go party for a while. Come back tomorrow and get some paying work done and wait about a week before you beat yourself up again. How do you expect the ‘Creative Juices ‘ to flow, if you don’t fill the tank ?? Have a few more ‘Old Mills’. Of course. Now you won’t care as much about the results. After this design is finished, you label it ‘Logo for on a truck’. Now do another one and when that ones eventually finished, it gets labeled “Logo for shirts’. Next logo will be the logo for your letterheads and so on down the line. All these logos should carry a common theme so it resembles your company, but there is no law that says…. YOU MAY ONLY HAVE ONE LOGO PER SHOP’.
Coca Cola or Coke_______McDonalds or Mikki D________Mercedes Benz or Mercedes_____________United States of America or USA or America or the US
And the list goes on. So don’t get hung up on right or wrong. Your own sign should go a little overboard and you can explain to your customers why you went a little ‘Gung Ho’. Everyone expects your sign to be a knockout…. so do it. If not, you might get passed over. Just do it tastefully. My taste is ‘Old Mill’… Breakfast of Champions’ ah, wrong logo……….
RJ California
I really like John Deaton's take of the original design idea. He didn't invest alot of time re-thinking the logo from the ground up, he just took a clients idea and greatly improved it in what probably took him 5 minutes. Of course their are 100 different ways you could take this logo, my logo or your logo.
Great points Gino on the ever evolving logo. I've had a running theme with my logo for many years but the overall look has changed and evolved many times.
I really like Dan Annotelli's books and ideas on small business logos. Thanks for reminding me to take another look at his great site.
Rick
I think it's easy to design your own logo....IF.....you can look at it the correct way....what the correct way is, is up to the person designing it, it's different for everyone. For me, I can be anything I want...instead of being the porky, shlumpy, geek grandfather that I am, I can be a neo-modernist elitist snob, or a fully tatted rat rodder or Racer X...all I need is the correct typeface, graphic and the right inspiration.
I dig John's reworking of it, it's arranged better, he removed a few things that were not needed and it's in the classic Sign Maker style that dhamlett15 is probably looking for. I prefer clean myself and I always try to do a clean version even if the client wants all the bells and whistles, but there are times where it just goes the other way. Certain business types can have more fun with thier logos, small sign shops are one of those businesses and the classic sign style works very well and I have always had a soft spot for it.
The reason I ask what client he was trying to attract was if he said Architectural Signage, then he is missing the mark, if he is a small vinyl/paint shop or does race graphics then he is in the right area.
One of the main reasons I do not like prismatic letters is that it's a trick that is used too much...similar to comic sans, papyrus and brush script. It is also too designed...it overwhelms a logo or layout just by how complicated it is and usually you have to bring everything else to that level to compete visually with it....this comment does not mean I have never used prismatics or that I will never use them, they are just difficult to get them to work right...John re-work is working right.
On the other logos you show the top one looks early 80's...not that is't a really bad thing but is that what you were looking for? The bottom one has major issues with your color choice on "Signs & Graphics" and (this may be hard to explain) you have competting verticle line...."Hamlett" is upright, Signs & graphics" has a natural slant and the yellow graphic is sheared but does not go with anything. It would work a little better if it matched one of the letterings slant or just square. If you notice John's, his has similar angles.
dhamlett15
Rick thanks for the info. I do mostly small signs, banners and race cars. I am leaning toward the one you said looked like 80's and have played around with colors a little bit.
Jillbeans
I love simplicity.
The older I get, and the more that special effects have risen in popularity with signs, I just find myself liking simpler things better.
I think Prismatic fonts are OK, but I think they lend themselves better to truck lettering. I do use them when I want more impact.
With a name like Hamlett I would go VERY typical and think of Shakespeare, even tho the spelling is different. Think of the skull scene..."Alas, poor Urich"
That has a lot of potential to be something unique.
If anything I would make the name in script and SIGNS & etc in the block text.
Your last example would be great if you do a lot of racing decals.
The Hamlet theme may not fit so well there, but skulls and racing go hand-in-hand (or bone)
hahaha
Love....Jill
PS
Is it just me or is 70s stuff really coming back into vogue?
RJ California
Rick
You have an amazing ability to disect a logo to it's core. Even with good logos it seems you are able to add something to make it better. I'm curious if you have written any books on the subject. I'd buy one.
