logo development feedback
iSign
I posted about my new domain name last week... StickerShockGraphics.com
I'm not sure how much energy I want to invest in a parallel universe to my existing business Island Sign, but for the upcoming car show at least I might unveil this new sub-catagory of products/services to see if it draws any attention & if a basic short&sweet website to match would be worth doing.
I played with some lettering for about an hour last Friday, called my wife to say I was coming home for dinner... & then couldn't tear myself away from spending another hour on it after promising to shut down for the night :rolleyes: The result was the 3 versions in the top left column.
This morning I put another hour & a half into it & wanted to get some feedback at this point. I kind of like the final version in the lower right & I did a black & white version for possible use on order forms or something.
oh yeah... forgot to mention, the yellow background is because I want it to look good on my yellow truck.
juniorcdn
I personally like the two bottom right versions. Why do you create so many variations of a simialar design? Is it common practice to create that many logo designs for one project? They all are really excellent designs. The prismatic font used is just awesome.
You are a true artist.
njsigns
I agree with Bobby H about the top left design, it has the most visual appeal to me. Easy to read and sleek! Very solid design, makes me want to know more about Sticker Shock! Good job! Just my $.02.
Gene
:cool1:
BTW - what fonts were used on Sticker and Graphics on that one?
Jen Goodwin
I really like the same one you do, Doug! But I like the border you have around the second one down in the left hand column; Maybe adding that around the one you like would give it more visual punch off the yellow? I'm also thinking the border should maybe fade to a blue (a nice 'intense' blue) instead of a gray. Just a thought! I think they are all awesome! You can't go wrong with any of them. :thumb:
2972renfro
I like the top left one, but maybe more contrast on the prismatic letters. The prismatic effect is not as strong on this one. On the others, the 3d is more pronounced because of the color variance and the gradations. There is almost no 3d appearance on the top left, although I like that design the most.
iSign
Harvest & Kreem, 2 more fonts from http://www.signdna.com/v2/cart/allfonts.php?id=all&gp=-1
As I put together a design in an attempt to capture something that exists only in my mind... I watch it evolve as I add, change or remove elements. At some point I begin to think I am on the right track, but I will then wonder about another direction that presents itself as a result of seeing what comes from the initial intention. These "forks in the road" usually take me somewhere I like better... but not always, so I will make a copy... tweak the copy, & sometimes abandon it & return to the first... more often I arrive at another fork, & I make another copy. So in the end I may have half a dozen ideas & each one could have colors or size relationships tweaked countless times still. I often stretch the whole thing up or out to see a different look. This violates a common "rule" (one I usually follow too) of not distorting fonts... but usually I won't do that just to make x number of letters fit into such&such a sized panel. I will do it if it adds a new & interesting look to a design without making me feel that the fonts look wrong. (Fonts with perfectly round characters, I would never distort) Sometimes I will like the new stretched out shapes... but I will reset the type with a different font to fit that shape without distortion.
anyway, as for the logos, I pasted in a few of my earlier batch in a different color scheme that I hadn't added to the initial post because I was looking at different colors, but since Jen mentioned blues.. here was some blue ideas I had... then I tried her idea of a border/panel behind the design I was liking most... then I asked myself what could be the appeal of the first designs that were getting some votes even though I thought I had inproved on them. I thought maybe the straight text instead of slanted text... & the slightly more symmetrical look could have been factors, so I tried Jens panel idea... with my own thoughts on symmetrasizing it...
Fred Weiss
In this last group I definitely think #1 in the upper left is a clear standout. What it achieves for me is just the right deemphasizing of SHOCK to where there is both a visual and a literal balance while maintaining the double entendre of the name.
The colors and gradients also serve to tone down what would otherwise be, perhaps, too strong a graphic ... which is the problem I have with the rotated blends in most of the other designs. They only seem to be there to radicalize the design (for the shock value which I understand may be what you're looking for).
I can only tell you I am drawn to #1 for its balance, legibility, and beauty.
3CGraphics
vote for upper left in post #7, although as mentioned they are all VERY nice. I think the blue on yellow VS the gold/yellowish ones on yellow set it off. I really like your art, VERY nice!
Steve
Bobby H
Arial Sucks.
Another reason why I think the #1 design works the best is it has the least amount of negative space intruding on the design. It looks more like a unified element.
Another plus is the fonts appear more in their natural state.
About the only suggestion I could make to improve it is perhaps making the work "Graphics" a bit larger. However, that may be difficult to do without the "G", "h" and "i" characters intruding too much over the "SHOCK" element. Doing design work seems like walking a tightrope at times.
I can also see the experimentation and progression in the various design generations. I think its only natural to have a lot of versions of a logo design as you build on it. Usually, I'm careful not to delete any previous elements until I'm satisifed with a design. You never know when you're going to want to back track and re-use some item from a previous version.
Steve C.
I like the upper left design in both presentations. I'd like to see the blue one with reds to replace the blues. Did you try using the same font for "Graphics" as you used on "Sticker"? I kinda think there are too many fonts at work. Also what would it look like if the word "Graphics" was straight instead of on a slant? I think you have some really good designs, just my two cent, for what it's worth....
After a second look, I do like the first one better, but with the word "SHOCK"
in white chisel letter like in the blue version.
iSign
OK.. here we go again.
by the way, thank you all for the feedback. In the end, I can't use everyone's suggestions... but I appreciate them all & like to do some tweaking of each suggestion so I can see the results.
With Fred & 2 Steve's now adding more weight to the already valuable opinions of Bobby, Genius, & 2972... I'm feeling a little torn.
I still like the "Shock Value" look & really like the effect when I tried to put the blue panel Jen suggested behind it, so I was drawing up a few variations of that along with revisiting the popular first design I began with & trying out Bobby's suggestion of increasing the size of "Graphics".
I had to try the warm colors again because wherever I may use it besides on my truck, I just feel like it has to be warm for some reason. Anyway I was just about to post pics when Steve C's reply showed up, so I added two more to see if the font & color changes he suggested would bring me around to liking that look. (I had also felt that the 3 fonts in 3 lines was pushing it)
so this is what I got now:
I had also put a few drawings on my truck photo before the most recent few replies... here are those files:
Rick
I think it could be done better. The borders are too thick and too many effects and lines. Of all of them I agree with everyone else on the choice of the first one. but I think something needs to be handrawn....maybe "SHOCK"...I did this as an example but with only a few minutes spent on it, there are some issues with it.
A good site where thier original logo is pretty bad, but thier updated initials logo looks pretty cool. They were the king of vehicle graphics foir a long time here in SoCal.
www.modernimage.net
Steve C.
Great job Doug, You wont go wrong if you go with any one of those. I'm kinda drawn to the center right one now. You have an extreme amount of effects being used, but in this case it sort of goes with the SHOCK idea. Suggestions could go on and on. Just this last one... if on the center right version, what if the "graphics" where justified all the way right and on a straight line? I also like the center left version. They all look really good.
iSign
Thanks for your thoughts & drawings Rick! The "too many effects & lines" comment hits home, because I have fell into a style where I do go on & on with some of those habits beyond the point of usefulness. I don't know if I will tear myself away from this affliction today... but it is a point well taken.
Steve, you are feeding the fire now by giving me that tiny bit of support on the idea I still have an interest in. I did try your latest suggestion. I agree, like with any design, that tweaks could go on forever... & yet, many existing designs could also be settled for. On jobs for me, I'm not afraid to keep tweaking past the point I could afford to go for a paid job. I don't expect to bore everyone beyond a certain point... but I'm not sure yet either.
Here is the latest change to the word graphics:
Marlene
I liked the top left one in both colors. I'd suggest getting rid of the inside outlines and the background showing thru so that it looks like a "sticker" rather than cut vinyl letters. As always, nice work Doug!
ENTDesign
Wow. Your different designs are educational for me to look at from a design learning perspective. If you are making yourself crazy, perhaps you need to not look at them for a while to let it cook in the back of your brain which appeals most to you. I went through this recently redesigning my own logo and came up with a completely different graphic after a billion iterations. Funny how you can usually get something for a customer in 2 -3 trys.
