Logo opinions
Chimley
Long time listener, first time caller...
I'm redoing my logo and I'm not much of a designer (not much at all). I am considering employing the services of a "real" designer but thought I'd take a crack at it myself for $hits and giggles.
What do ya think so far?... (be kind :smile: )
Thanks,
Chris
D&Tgraphics
I agree with Rep. Thicken up the fonts. Make them the focal point. Right now it looks more like a sign than a logo. Maybe try and incorporate some sort of bulls eye concept or crosshairs.
Chimley
I thought the fonts were to thin from the onset myself but that's the thickness that they came in and I liked the look of the type. I'll see about picking a new fonts or editing them somehow (don't know if I can do that). I did kick around the bulls eye concept back in some earlier revision but I ditched it because I had a hard time making it work....It looked a bit "cartoon-ish". Not that I mind cartoon-ish but it seemed to go in the opposite direction of the "neat and clean" look that I think I have with this design. I'll see if I can't revisit the bull eye thing.
Thanks.
Chimley
OK.. Take 2
Bolder fonts, thicker arrow, more contrasting colors
Thoughts?
iSign
remember, "form follows function"!
your panel shape is attractive, but it looks like you started there, and then filled in with a name that doesn't match the shape. That's backwards in a way. The function of the graphic (agree it doesn't have a logo look yet, more of a sign layout) ...but, the function should be to identify your business & to do so in an attractive & memorable way. After that's working, you can fit a panel to your layout.
If you really want to get it working for you as a logo, an easily recognizable form that becomes your brand & is recognized before it is even read, and your panel shape could help achieve that recognition, but it should fit the layout. I think the border & perimeter should be all sharp corners, or all rounded. The background could have a subtle bit more interest, possible the bullseye (although it seems a bit cliche) or pinstripes (straight lines like pinstripe suit) ...and the fonts should fit the sign... "Accurate" is so sharp, so I think I'd want sharp corners on the sign.
ok... I did a 5 minute sketch... I'll go scan it.
iSign
ok... I guess another suggestion when working on any design, start with a pencil... your choice of fonts, panel shapes, or the worn out paths most followed by you, in your software, in your daily grind... those ruts & font limitations will steer you wrong... free yourself of that & just draw... let something original emerge & then tweak it... do several thumbnail sketches (I have 2 or 3 variations I already want to try after whipping up one... you should make 5 or 10 when it's for your own personal identity) Once you have a good skecth, you can push yourself to capture the intent withing your software & then you bend the software's capabilities to your will, & not the other way around!
jscarl
:goodpost:
Chimley
Will do... you had me pegged in your first post iSign... I understand & agree with your advice. I need to get some more practical design skills under my belt before I can execute what you suggested. At this point I'm still reliant on a fairly narrow skill set. I can't tell you how much I dig this forum... Lots of good stuff here and not enough time to sift through it all.
Jillbeans
It really looks to me that you found a sign panel shape that you liked and made that your basis.
That's what I did when I got my first VectorArt book.
"ooh that's pretty! What can I fill it with?"
But then I learned that the main part of your design should be the message. The panel (if any) should be secondary, particularly in logo use.
It should also echo the shape of your words, even if they are an odd shape.
I like the bullseye/arrow idea but think it might pertain more to a sporting goods store.
I think using something like the old construction type letter as a base might be OK. Or just something precise looking. I wouldn't use calipers or a measuring device, though.
Here's two quickie ideas, I am just trying to get warmed up for the day.
Love....Jill
Marlene
try doing it like Doug showed as that would work with the name and the shape of the sign. the last one you posted is OK, but it looks like elements placed on a background. look around on the web at logos. do a search for threads posted by Jon Aston as he has posted many links to sites that will be a big help in inspiring you.
Chimley
Almost afraid to post another version but here it is. Your advice is penetrating my thick skull...
Jillbeans
I prefer that one.
If using a script, you must weld it.
And I think I'd probably use a prettier script but apparently people get sick of me pushing Valentino. Try Alpine Script or Louisiana from Chuck Borges or Red Sable from Arthur Vanson.
Or Valentino from Art & Signfonts.
Marlene
why the arrow? it looks more like you are being attacked than accurate. the bullseye and arrow makes a little more sense. why did you choose the name accurate? is it because your work is always correct and what the customer wanted? could you do better with a tagline to say what it is that makes your business specail rather than a graphic? ask yourself questions like this when you design and then see if what you did answers them.
what did your old logo look like? is this totally different? can you rework and update the look of your current logo? totally changing a logo isn't always a great idea if your logo has been out there and know by customers.
your script font needs a lot of work as it shows all the connections and some are way out of alignment.
