Logo...revised...let me have it.
High Octane
For those who saw the first attempt or those just now seeing it....let me know what you think...it's for a music production co. / radio station.
kazoosigns
Professional Music Servies?!
It's definitely a lot more legible with the text turned. I don't see a purpose in having the flames there; aside from using the wording "Flint's Hottest..." I don't think it adds to the design.
Tim D
Much better. I was gonna suggest making the ((( ))) white. I like the flames, but maybe something a little different, more movement.
Billct2
I like the look, but find the FUll confusing, doesn't read FULL at first glance, more like "fooey"(fuii)
For me…. The one without the flames kicks some serious butt. However, and there’s always that ‘however’, I would make the two ‘L’s upper case along with the rest of the copy. It’ still doesn’t read well and the apostrophe in the word ‘Flint’s’ looks odd. It should be higher. That looks like it doesn’t have enough strength to stay where it belongs while everything else is screaming strong stability.
Overall, I really like this one.
The other one has too much red competing for attention.
vid
I think it's a funky cool layout - It works for me as a T-shirt layout or sign layout. I'm still having a hard time seeing it as a logo.
For me, one of the determining factors that makes it work as a logo, is getting it sized to fit on a 2" x 3.5" business card and have it read well. Seems like your type would get very small for that.
I'd suggest that you simplify it more. Save the flames and notes for collateral material like the T-shirts, Wraps and Bumper Stickers. That way you wouldn't be locked into "designing around" the logo in the future.
I think you've got great ideas, but you're trying to put them all into one design ...and from what I'm seeing, it looks like an opportunity to sell a package of designs now and into the future.
my .02
RJ California
I think it looks great. I couldn't really read the version you posted earlier. You can easily pull the lettering and most important elements to make a simpler logo version (for 1-color uses or a more corporate look). I'm guessing that the lower case "l's" are for symetrics --- I can still read it at a glance though. For business cards, van wraps, t-shirts, etc I think it's good just like that. I like both new versions. Very cool!!
Jillbeans
I like the one without the flames.
I dislike the lower case lls...looks weird that way.
Could you stack the LLs, as if the second one was sitting in the first one's lap?
And when I add an apostrophe, what I do is to type the word without it, then type in a ', then ungroup and hand-position it.
I do like this version better than the sideways one.
Love....Jill
SBowlerDesign
I don’t think you need the flames. I would use a different typeface for Flint’s Hottest... and Productions. The typeface doesn’t seem to go with the clean lines of the illustration and the word EARFULL. This one is much better than the first example you posted...very legible. Try Jills suggestion for the uppercase LLs. You are almost there!
RedlineMan
Wow!
That's good stuff! Really great concept. I would combine a lot of the changes mentioned here.
- Yes, the Ls need to be upper case, which I realize will not be easy.
- Yes, the apostrophe needs help. I would make the T smaller, the N bigger, and sneak the apostrophe in sort of above the T.
- I do like the flames, and the notes, but as Vid said, it may not work for small sizing. The basic logo might be better served if it were stripped down. If they want to do more extensive promotional material whose size would be conducive, then the details would add more depth and interest.
My bet is go with the flames, skip the notes, and fix the Ls and apostrophe.
I like it! :thumb:
RedlineMan
Just Playin.
The L thing aint easy. Not sure this works. Like I said, just playin.
Fun to play with killer koncepts! :Cool 2:
chopper
I like the second one and yea I think they are right on the L's and the '
but I must say that your designs are some of the most unique designs I have seen in a long time great job!!//chopper
greeter896
Logo Revised
I would definitely go with the one without the flames! The design looks much cleaner without them. You may want to bring a little more attention to the web site text and highlight it a bit.
I think you have yourself a great design there! :thumb:
Best Regards,
Gary / Sign FX
RJ California
I like the idea of the stacked "L's" that Jill mentioned and Redline brought to life. I think that might be worth looking at. As far as the flames go, who says you can only have one version of a logo --- I like the flames and they might have a place somewhere, sometime.
I have 5 versions of my logo, all with the same theme, but for different uses (and I'm a small signshop).
