Looking for any suggestions/critiques
myronb
We're trying to update our logo. I think we're heading in the right direction, but I wanted to get some outside opinions. First is what we have now, 2nd is the new design.
Thanks,
Myron
myronb
Wow! How do you like that? We must have the perfect logo design!
:beer
Just kidding. I just wanted to bump this back to the top because I think it needs something, but I just don't know what.
Thanks Again,
Myron
Jillbeans
I don't like the script in an arch on the top...
maybe try another non-script font.
The drop shadow only adds clutter on the script.
Also, the blue on all the RO-MAC elements is a bit overpowering to me.
This could be fixed by eliminating the light blue outline/drop shadow on RO-MAC,
or by doing a thin white outline followed by a thicker grey outline.
(I don't think it needs the drop shadow at all)
There is a bit of interference with the "g" with the grey border which could be eliminated by making the extender of the "i" flow better into the "g" as if it were hand-painted, and dropping or raising the "g" just a tad.
I'd also eliminate that front connector on the "i".
(whichever looks better...the script seems a bit stretched)
I tend to play with my scripts by ungrouping and moving them for a bouncy look, then welding.
Again, you have an arch in the script, which I have always been told is a no-no.
I am just being nit-picky...the logo does have potential.
love....Jill
Techman
IF you wish to use a script font on an arch,, there are a few around that can be arched. That is they are script looking but the letters are not slanted. I cannot recall exactly which ones are at this moment. I remember this because I did a hair shop that insisted on a script,, and insisted on an arch. I quickly found one that was just right. Check signfonts. Maybe i bought it from them.
But the general rule is:
Do not Arch script fonts because the letters are on an angle does come out right. Looks distorted..
vid
I'm sure Ro-Mac means something... but it doesn't make sense to me, especially with the looooong dash between the letters.
I'd first shorten the dash and make it look more logoish. Again, because of my confusion with the way the letters line up. I'd reduce the size of the name and emphasize the product - Signs. Also, you can reduce the confusion with the word by using a sans serif face and making it easy and quick to read. Right now, I'm trying to hard to figure out what a Ro-Mac is and miss the "signs" part.
You've also got a lot of lines going on and around the letters. That also throws me off... It looks like you're trying to make a shield to tuck your type into. If you want a background shape, make a background shape out of color. The lines are get distracting.
Admittedly I got a little funky groovy with this one (see attached), but hopefully, it'll give you an idea or two........
just my .02 ...take it for what it's worth
Best,
vid
Jillbeans
I'm thinking that if you colored in the back outline it might help.
Looks like you were going for almost a Harley shield thing.
I tried this with some Atkinson & Vansons.
Just a suggestion.
Love....Jill
myronb
Thanks for the suggestions. We're working on it! Also, I think the jpg doesn't do justice for the blue in "ro-mac" It has more of a dimensional look.
myronb
OK, Here are are some changes we made. Colors obviously have been changed. Put a gradient on RO-MAC (by the way, ro-mac is an abbreviation for the owners name, that's what he came up with when he started a trophy business in his garage. Not great, but it's what I have to work with:help: ) Anyway, We kept the script but straightened it up a little--I think it works OK. How do ya like it now! We do need to tweak the Signs: removing the connector on the "i" & making it flow better. Well get to that eventually.
The colors are a little bright on the jpg. It should be reflex blue, process blue & harvest gold. Does this work or should we aim towards other colors?
Thanks Again
Myron
Jillbeans
Better...More readable...but you are still arching that durn script!
It does have a lot more "pop" than the original tho.
Bottom script still looks to distorted to me, but that's just me.
I would tweak that by re-ryping it from scratch,
losing the "i" connector as mentioned, lose the arch, and make it an upward slant.
And un-squashing it.
Love....Jill
Jillbeans
Here's a quick mock-up of what you have...sorta...
Just wanted to try out Samster Script!
Also to illustrate a slanted but not arched script.
I do think you are nearly there.
Love....Jill
I like where you’re going.
It’s definitely getting more legible. Think about the possibility of using a darker blue or even black for the outline around the words. Remember, when you’re designing and staring at a computer screen you’re looking at things about 18” from your nose. Anything will look good, because you’re staring at it for a great length of time. Keep the 2-1/2 second rule going.
The other thing is, look at some of the samples sent in by some of the seasoned sign painters, like John Deaton, Mark Flair, Geary… What do you think makes their signs, cartoons, sign designs and layouts look so good ?? It’s the high contrasting of colors. The exaggeration of colors is what sets good designs apart from mediocre. However, it has to be tastefully done. When you take colors beyond ‘your’ comfort zone, then they begin to take on a new look… the look of a sign which is meant to be read from a distance and not a couple of inches from your nose.
:peace!:
myronb
Jacki said:
The dot on the I in Signs needs a Yellow pinstripe as well.
Yeah, there are a couple of little tweaks that need to be done, I'm just trying to get the look right. I know that Jill is still cringing over the arched script on top, but I still like it:help:
btw does it look yellow? It should show up Lime Green.
Thanks,
Myron
vid
I'm not sure you've gotten to a "logo" in my way of looking at this stuff. Seems like you've gotten to a sign layout or T-shirt design.
Jill isn't the only one the cringes at the arc of the script. The arc messes with the flow of the script character and distorts the rhythm of the type.
Also the outline around your background shape confines the design. It also gives it more of a sign layout feel than a logo. Either make it fatter so that it looks like it's supposed to be there or get rid of it. Right now it looks like something that was placed there because you weren't sure what else you should do.
Likewise, fiddling with outline colors is another queue to me that I'm overworking something. If an element is not working quite right, make a commitment to change it... It doesn't look like you're going far enough to give it that punch you're seeking.
And being nit-picky, the drop shadow and the chrome look seems like it was placed more for effect than design, too. Define a light source for your drop shadow ...and make the chrome reflect something other than a horizon wobble.
I think your efforts are fine, but I'd like to see you push it further.
Attached is another take on your design for example...
