MDO Printing
Hi Geno,
Sorry about your problems with MDO printing on the Dilli. Not surprised because MDO is only slightly better than plywood to get to lay flat.
The other problem besides the warping is that in the quest for better print quality and detail the printer manufacturers are using heads that drop smaller and smaller drops. No one wants a 30+ pl drop machine but that is exactly what is required to print uneven surfaces like MDO or even interior doors with inset panels.
Printers that use 14 pl heads like the Dilli, Agfa, Oryx and other like the Oce/Fuji using 6 pl drops will all have problems because drops that small turn into vapor if the drops travel farther than about 3 mm, 2mm with some heads. You can try to constructed a frame or sled that may flatten the MDO but it will be tough to get the entire 4x8 sheet surface to with 3 mm across the whole sheet. Even with a true flatbed and a large vacuum pump it will be tough to get it totally flat.
A printer like the Zund 215-C or 215-Plus using 40 pl drop Xaar 500 heads does fairly well on MDO. You check the MDo for the highest point and set you height 3 mm above that. 1/2" (13mm) MDO with a 1/4" (6MM) warp is about 18-19 mm at the height ofthe warp. With the head height set to 22mm the max distance you will shoot ink drops about 8-9 mm and with 32-40 pl drops. The image still looks OK particularly for a 4x8 real estate
sign.
The way you print and mount on the MDO now is about as good as you are going to do on the Dilli. If you have enough MDO to print used Zund printers are pretty cheap these days. Drop me a line if any of you might be looking for one. I also have a Dilli 6 color that I am helping a customer sell for $47,000 with all new print heads (heads to be installed at install) if anyone is interested.
Best regards,
Bill Grambsch - WP Digital
201-675-3334
bgrambsch@polytypeamerica.com
