need help pricing signs with multiple logos
slappy
First off, not my layout idea, theirs (and ignore sizes handwritten in)
second, I plan on using polymetal sheets for these signs, but cannot figure out what to quote them cause i never had this many different colors, files and size of this order before.
so here are the signs my customer wanting. (pic's attached)
they will both be 5'x6' polymetal signs
each logo on the signs, my cusotmer has emailed each company and got the vector artwork which i now have
I plan on doing this with die-cut vinyl. might need a few prints for logos, but i'm going to try to do as much as possible diecut
There is also another sign 5'x30' polymetal that will have the business name in green with a blue dropshadow w/ outline then a tag line in black under.
I got a quote for the polymetal at 98.97 a sheet if i buy 5 or more. (save $10 on each board)
I don't know, i'm lost.
I'm coming up with a little over $2000 for everything, but i'm not sure if that's too high or to low.
Any help? Any suggestions?
Most of those logos should be provided by their marketing departments in vector format with ease, so you basically won't have any converting costs. If they aren't, there isn't one there that should take more than 10 minutes to scan and fix up. I'd charge for your normal markup on material, vinyl usage and probably $25. a pop for each logo.
Your $2,000 sounds a little thin, but if you can live with that.... go for it.
slappy
what about $623 each 5x10 panel for the 30' on $1869 total
and the 2 5'x6' ones $463 each $926 total
$2795 out the door
may even discount it $250
nothing under $2545 sound better?
slappy
i originally priced the 30 footer at
oracal cast vinyl $896 each 5x10
and intermediate 651 at $623 a sheet
then he added 2 more signs (the two 5'x6' and asked if i could discount it a lil)
I should have mentioned about $2200 in post 1. I screwed that up.
i dont know i dont know i dont know what to charge!
Jillbeans
I would charge $800 for each 5'x10' and $700 for the 5'x6ers in HP vinyl.
With the 5'x6ers you will have a cut off but it's an oddball size.
Plus you have to cut all those different colors of vinyl etc.
