Need some suggestions
DRPSignsNGrafix
OK just got done drawing this one up. Haven't done anything with colors yet. It's in Black and white to see if it looks decent. Let me know what you think. THanks
Marlene
the slants in MD and motorsports are conflicting. the tach shouldn't have slanted numbers. maybe it should have a white dial so it doesn't blend into the rest so much. the flames seem to add nothing. it also has the look of many other designs for this kind of thing. that could work as people know what it is the company does or it could work against them as they will look like 1,000 other companies.
DRPSignsNGrafix
Thanks Marlene. I fixed the Slant in the MD and Motorsports. And changed the numbers. The customer is all into the flames. I thought about soe mflames off the sides but I didn't like it at all. I'm hopeing when color is added it will help the flames some.
Tim Aucoin
I'd tighten up the kerning a little... in MD and Motorsports... I think once you add color, it will help with adding some separation and depth.
Marlene
I guess I just hate flames as they are so over done. the slants look much better and the number look good. once you add the color, it will pull it together.
iSign
I just sketched out a few thoughts, because i was too lazy to try to find words to communicate them. My quick sketch is not pretty, but it helps show my thoughts.
Two things, first I don't think your design is ready to introduce color, so I'd suggest you go back to black and white for now. Second, I think you have a chance to create real depth, but so far it's not happening. The flames look like clip art right out of the box. Use them as a guide, and use your own vision to decide how you want the flames to conform to this project... then draw your own flames. You will be so much more proud of your design that way, and it's almost guaranteed to look better (assuming you draw well :omg:) Also, the furling flags invite the illusion of depth if you have them wrap around the tachometer. That's what my drawing tries to show. Instead of the flames being in the back (what's on fire?) ...have the tach on fire, & have the flags furling out from behind the flames, then in front of the tach. this creates depth & pulls everything together. Also, you need to redraw those flags, or find clip art. Flames can be organic... but checked flags have to be geometrically perfect!
Marlene
I think I liked it better in black and white, sorry. a purple tach with colored numbers? why not make it look like a tach red lining with that little red area that you see on a tach? the purple is odd. also, fix the flags so you don't see the flames in the white area as you wouldn't if those were really flags.
Tim Aucoin
Agree with Marlene on the tac & flames behind banner. On tac, if you make the numbers color... high numbers should be red... lower numbers green (to be realistic). I'd also tone down the (lime?) yellow color a bit... it screams and distracts from overall design.
