New logo
JERHEMI
Another logo idea, let me know what you guys think! Thanks!
S
Sign-Man Signs
Guest
Good, But...
Red, White, Blue always a winner. Maybe your phone number. We put it on everything. Can't call you if they don't know the number.
:cool1:
JERHEMI
For the logo itself I think I'm going to leave the phone number off. When the phone number is needed I'll add it.
SAS
i think you should pull the arrow out of the Y a little it would make i easier to read
MAB SIGNS
I personally would rotate the arrow head to te left a little so the Y isn't blocked as much.
Sorry I came back to this after being away from computer and SAS had beat me to it.
iSign
I like it a lot. I think it is a vast improvement over your earlier attempts, & I'm glad you decided to remove the phone number.
I agree with pulling the arrow slightly back from the Y, but still overlapping a little for depth.
Then I think your red outline should go, and the dark blue one on the arrow. They destroy all the depth you create with that arrow & lock everything back onto the same 2 dimensional plane.
I'd even try changing the blue outline (the furthest out one) on your name to a darker blue, or a black to keep it distinct from the arrow.
JERHEMI
Let me know what you think!
Thanks guys I really appreciate your input on this! I took a few of your suggestions and made some changes. Let me know what you guys think! Also, do you like the background or should I keep it out? Thanks again!
P.S Merry Christmas to everybody!
GB2
Old Member
When you asked about the background, it made me really study it. I found that without the background it almost looks like it has perspective and the "YOU" is starting out down the blue path, I thought that was interesting and maybe could even be enhanced. It doesn't have that same effect with the background but I think the background is essential. Without it, it looks like an unfinished design. One thing I don't like about the current background is the part underneath between the arrow and YOU where it just stops. Maybe you could adjust the gradient more from side to side so it's darker on the left and fades out on the right where it won't have to just stop like it does.
I like the coloring of the first display for everything, including the outline around the letters. I like where you finally landed the arrow on the bottom samples. I would only yet take out that wave look in the red portion of the letters.
JERHEMI
More tweaks!
I made a few more tweaks, let me know what you guys think! Gino, you really don't like the wave in the letters? I think it looks like a reflection and give the letters a little depth without doing a chisel effect. Any ideas for a better design in the center? I think something that is has a little more design to it rather than a gradient would be better but I can't think of anything. Also, I need to make another version with my phone number but can't decide whether to incorporate an oval or something behind this and add the phone number on an arc simple underneath or what, then after this I have to figure out a layout and what colors to use for business cards and such..any help would be much appreciated!
Jillbeans
What is more important?
The arrow or the name?
You are also heading into that light blue/red eye vibration area...
I'd make the arrow thing smaller and maybe even consider using a number "2" in a swooshy casual instead of "to", bigger than the text.
Love....Jill
Jillbeans
Maybe like this.
I actually like your first one better than the last.
Love....Jill
Mike Paul
Super Active Member
The width of the arrow tail on the bottom looks to thick where it meets the head. I'd reduce it some. That would also make the wings of the arrow head a little longer which is also needed. Try slanting the tips back a tad to create more movement/flow.
Doyle
I think that the one without the background could look better if you added some dimension to the arrow (bevel, highlights, etc) but not overlap the Y so much, you want your name to be dominant over everything. Looks good!
Doyle
