Our new logo
We recently moved into a large manufacturning facility with a reception area, offices, large layout rooms and a HUGE shop. We also just gained UL approval to manufacture electric cabinets and channel letters. I thought with all the new things happening it was time to work on my own logo instead of everyone elses.
Here is the finished piece. It will be on the front of our building about 16 feet long. the faces will be vacuum formed with transluscent digital prints. the perimeter of the sign will have true neon border tubing.
The sign is going to the router table for production this week and the business cards are already in so it is a final logo. Looking for your opinion anyway.
TIA
iSign
Jerry, it looks good to me too.
But, I will offer some minor tweaks to consider anyway.
1. the tagline is so far less italicized then the name that it jumps out at me & I would push it over further until it matches. (I would also consider bringing it to the left so it doesn't break out past an imaginary line drawn down along the right hand side of the N in Design)
2. Maybe the shadow from the name should include some shadow to the left of the S (in Pro Sign) that would fall on the circle graphic behind it (maybe they need to be on different layers when the shadow is applied)
Also, your highlights are created by a light source at the left... so I think you should switch that... or switch the shadow over to the right.
3. This suggestion would require the most work to address... but is the most important in my opinion. The bevel on your name looks cool except on the narrow horizontal strokes at the top of letters like P, R, S, G and D. If you route thos letters to create an actual prismatic effect... those areas will never rise up to the full thickness of the rest of the letters, as the bevel will remove any flat face on those areas. The "P" in the graphic is far better suited to that bevel treatment, so I would go back to the original vactor layout & use (or create) a bolder version of that font so it has enough stroke width to handle that bevel.
4. Sorry, but now that I started critiquing... the oval embellishments seem a little confusing. The outer dark areas could be seen as a beveled edge, then the next contour in could be a flat blue surface. Then inside of that is another ring that may be seen as another bevel receeding back from the flat blue surface... but the curved deliniation at the right & left sides looks less like a 3d representation... and more like shapes for the sake of having more shapes. The spherical center almost has that feel to me too... but mostly because the shapes around it started to lose me... & the effects on the "P" lose me further.
It looks so good, I only offer this critique, because I think the last 10% deserves to be tweaked for hours before making a 16' sign from it, just so you won't see things suddenly 5000% bigger... and wish you tweaked them a little first.
Jillbeans
I'm not a huge proponant of red, Jerry, but this design is screaming for it!
I'd make the name in a burgundy to bright red fade.
And the oval thingy? I'd make it look like chrome or silver, with the "P" in bright red.
Tagline should be red and ya need to fix the slant. I do like the design tho.
Looks real racy to me!
Love....Jill
Mark L
I like it Nice job
Once you have it on the building post a pic
I would like to see it with the neon... cool
Geary
Very clean commercial/custom look Jer. I'd spot that one a block away! :thumb: One question to propose though: Did you try it with some lower case versions as well? Because with lower case added...it would read from even further away.
~Gear
MAB SIGNS
Agreeing with Doug, the perspective between the oval and the text is confusing but overall it is a very good logo. Giving the formed face embossed text would make it pop more. Please give us a peek once completed.
RonSF
I like it also, but think that, in addition to tweaking the lower line, you should either align the two "signs" or move them more out of line. I don't like the way they almost line up.
