Playing with my brand - Looking for input
speedmedia
Hey all,
I am toying with the idea of playing around with my brand a bit. I guess I am looking for some input from folks to see what you might do to make this brand stronger or would you leave it alone?
Throw it in the trash and start over? Give it to me. Maybe I just need to keep it as is....
Thanks,
Kurt
BTW - The top one is the commercial version and the one with the flag is the logo we normally use for motorsports based projects.
Letterbox Mike
I've always liked your logo. But looking at it, see how it would look by losing the slant, de-emphasising the gradients a little bit (not totally), and try a slightly chunkier font. Also, the flag in the bottom one maybe is a little on the generic/flat/stale side. I like it's overall shape and placement, but it looks a little like clip art and doesn't seem to blend in with the rest of the logo...
Mike Paul
Super Active Member
The text and panel need a little more breathing room and the shape of the panel with your text distortion doesn't blend, match, or transition very well.
speedmedia
Would it be better if I don't try to follow the panel shape and keep things straight? This gives a bit more room to breath as well.
What do you think?
Thanks,
Kurt
I like it and I also think you could pull in from the edges a little for better balance.
My only critique would be a simple one..... personally, I don't like stars that are some version of red or anything near it. I would try some different colors of the star.... but like I said, that's just a personal preference call.... it doesn't make it right or wrong.
iSign
I agree with Mike's comments, & think the rework in reply 4 was an improvement. As Gino noted, I agree that it could stand even more breathing room.
Last thoughts, there is some irregularity showing on the vertical orange line at each side, I would fix that to a straight orange line & your radius looks stretched, making it harder to match it perfectly between the black panel & orange pin line. I might consider redoing those, building off a segment of a perfect circle. The stars look too low, so I would visually center them to MEDIA.
(curious to even try changing the orange to a silver border & turning it into a reverse panel for that lower 30%, with MEDIA in black on silver)
speedmedia
Hey guys
Thanks for all of the feedback. I have made some changes based on some of the comments and would like to see what you all think.
Thanks,
Kurt
speedmedia
Why is it leaning to the left a hair?
Not sure... Didn't even notice it until you said something, now it is making me NUTS! lol
I will mess with that a bit more but still looking for some overall feedback on the rest of it.
Thanks,
Kurt
iSign
thanks for trying out my idea... I like being able to see it... and i like it...
but I think I like your orange one best still!
...unless you want to show us the reverse panel idea, with orange :rolleyes:
speedmedia
Guess I probably should have included that before...lol
I also like your idea but I don't know if I like it with the orange. I like it with the silver/grey but then it almost seems to be lacking to much color...
What do you think?
Thanks,
Kurt
iSign
I think I might like the wave in the letters more if it was not anywhere else but the letters. I meant to write that yesterday... but it bugs me even more when it changes the orange shade. Having it effect the background seemed to take away a little for the effect on the letters... but having it tint the border really bugs me...
Other than that... I think you have a lot of viable options... sleep on it for a few days... see if that helps...
Rick
I think your original logo design was always good but had some oddities.
-One was the "S" It's a weak "S" on that typeface.
-The bottom type was too stretchy.
-Some of the comments about the corners and inline.
-The glassine look, not sure it's needed.
-The shape is leaning to the left, I could see it as an avatar, but really stands out when blown up.
Below is using lines to show the deformity. I would just redraw that shape.
Also are options with a different type with a better looking "S", less distortion on the bottom type and another typeface option. Also note the flat "horizon" look on the top left logo, the shape has consistent corners and slightly more pronounced peaks.
speedmedia
Hey thanks Rick!
I will use your suggestions and start by redrawing the shape. I was always a bit iffy on that font in particular the "S". Will see if I can find something a bit stronger.
I like the glassline look more so to give it a bit of depth and character but I use the flat look on things as well, just depends on the application.
I always wondered if it needed anything incorporated to show "movement" hence SPEED, but I was unsure how without introducing another element which I don't believe is needed. Any input or thoughts on that?
Thanks again to everyone input is greatly appreciated!
Thanks,
Kurt
Jillbeans
The one in post #15 looks the best to me, but none of them say "speed".
I think it is the serif font that's doing it.
Looks rather stodgy to me, no matter how you tart it up.
MEDIA looks really smashed.
Love....Jill
