Price Check on 4x8 Cut Vinyl Sign
cptcorn
adad
What's the going rate in your area for a 4' x 8' sign. Something similar to this in coverage, black boxes would be some sort of logo or design.
OldPaint
whata ya puttin the vinyl on?????
CORO
ALUMICORE
MDO
SENTRA
SIDE OF A TRUCK?????
simplest thing i can tell ya...
$5.00 sq ft just to cut it and tape and hand to sign owner.
4x8=32 sq ft. $5 x 32=$160.
now if you apply it, ADD, if its HIG PERFORMANCE ADD....
if its on alumicore/mdo ADD price of material + profit....
when i do a 4x8 on a alumicor/mdo i figure $10-15 sq ft for total sign.
cptcorn
adad
Intermediate film, Alumalite or MDO... I'm just trying to figure out a decent price, and really if its worth it or not. So just kinda getting a feel for whats going on around the country... 48" material so applying would take 10 seconds ... hrmmm
OldPaint
don matter if it only take 2 SECONDS TO APPLY IT!!!!!
you still need to make money....i dont figure my work on how long it takes me to do it....if i did i would be doin that part for nothin....since iam so quick at it...
i used to PAINT A STOCK CAR, 3 number, 3 colors,2-4 sponsors, pit crew, drivers name..
ALL IN 3 HOURS....so i made $60 an hour(all profit, minimal materials)
i never told em i could have it done in 3 HOURS......for $180!!!!!
put a sign up so you can see it...
WORK SMARTER.........NOT HARDER!!!
cleanmywound
old paint is right,
Any 10 yr old can do it with 20 yrs experience.
Just did 2 back lit translucent acrylic, h.p. 3 color simple graphic w/ lettering, 800.00 each.
Thyezer
I'd go with $10 / linear ft of vinyl 24"(per color)...16 x 10 = $160
overhead rate for design time...($50/hr) 1/2 hr = $25
overhead rate for application time...($50/hr) 1/2 hr = $25
cost of substrate * 150% (Aluminum $3/sq ft) 32 x 5 = $160
+ delivery charge...($25.) $25
Total: around $395...now you can do it cheaper... heck..put it on a window for them and save them some money...but make sure you add for the longer installation time.
You don't always have to sell something for what it is worth...
but you should always make it worth what you sell.
Sell Your service...anyone can make a sign and sell it cheap.
cfbeagle
Get yourself the "2008 Sign Pricing Guide" from SignCraft.
It will be the best $20 you ever spent!
To answer your question tho...
I would be between $400 and $650 depending...
cptcorn
adad
You misunderstood me... When I say it takes 2 seconds, it means im not worried about how long its going to take me to put it on... it will be charged out correctly... It's more me talking to myself... If you knew me, you'd understand I'm the exact opposite of who you described. Really, i hate these, how much for this and that threads... but i actually needed input on this...
Somewhere between $1.00 and $500.00, depending on different variables . . . Hope that helps !
Yes it does... :)
I was just thinking about this actually. I just noticed it existed yesterday.
I have -never- lowballed a job, infact 90% of the time im higher than everyone else. The customers I lose, are the ones i don't want. The ones I keep are the ones that appreciate my work, and I service them to the absolute best of my ability.
Normally a job like this i'd charge about $450/sign ... Now my main reason for all of this is to setup up some sort of understanding of what everyone else is doing for something like this, so i can check to see if my base price is within what everyone else is doing (location adjusted). Which leads me to this... They're looking at doing about 200 of these per year. So in reality im just making sure my base is correct and then i can determine some sort of quantity discount... Thanks for the responses...
Alex
bob
Assuming one sided. For intermediate vinyl, $297 plus 200% of whatever the substrate might be. For cast vinyl it would be $330 plus 200% of the substrate.
WhiskeyDreamer
Professional Snow Ninja
i use the signcraft guide as well...it's a wonderful thing...
for the sign, s/f i'd be around $450 - $550 depending on the logos (if they're printed or cut)
Techman
Yes, you sell it for more. Never less. What is a good sign worth? it is the sum of its parts plus the value it brings to the business it supports.
ChiknNutz
Thanks for the plugs folks.
I'd price this as follows:
4 x 8 x 1/4" alumalite with Oracal 651 black vinyl: $384.70
4 x 8 x 1/4" alumalite with Oracal 751 color vinyl (not black): $405.79
That is a bit over 3X cost which I've found is a decent ROT for a sign like this when in doubt.
No design time is included and not sure what you'd do about those "logos" there if they are printed or other colors. This price assumes just the one color of vinyl.
Though MDO costs less in mat'l cost, I charge just about the same as alum. comp. due to the time of prepping the MDO....even if you buy it painted, you still have to prep the edges.
cptcorn
adad
What about if the sign shop keeps the substrate for use later on... granted there would be a charge for the 'use' of the substrate... but again, this would be temporary stuff.... since my target company really has no use for them after a couple months....
ChiknNutz
Personally, don't think you want to get into renting a cheap sign...what if it's stolen or damaged while in possession of client? Sure, draw up a contract, but then you probably gotta chase the money down...seems like a big hassle for a little return. If they want cheap, sell 'em banners.
high impact
Anywhere from $12 - $17 dollars per square foot on alumalite depending on complexity variables PLUS design time, edge cap, etc...
