Price check on CNC v-carved Cedar sign
dman0427
Hello all,
We have a small v-carve job to quote.
It's for a local private school.
Below are the specs.
4'x4' sign (two 2'x4' cedar panels supplied by customer)
v-carved lettering painted black
Single sided
trimmed in 1"x4" cedar (I'll have to supply trim)
Clear coated/sealed both sides
No installation
customer drops off material & picks up when done.
Attached is the layout.
I'm coming up with about $650
Am I in the ballpark?
What would you get for something like this?
Thanks in advance :signs101:
I would rethink your wanting to do this project with that layout.
First of all, the layout has a lot to be desired.
Second, I'd never want to 'V' carve those little serifs on customer supplied wood.... let alone the slashes and other skinny crap on there.
Wrong font was chosen.
Executed with a better font, maybe around $1,300 to $1,400.
dman0427
Thanks Gino.
I don't care for the font myself, but it has to match existing signage.
...So my figure is HALF of what it should be?!?
No, it's half of mine...... based on our shop, our ability and local competition. I know what I need to do that sign and I know no one else around me can really do a good job.
What it 'SHOULD BE' is entirely up to you. Did you happen to see, I'm In Pennsylvania and you're in Texas...... things could be much different down your way.
SignManiac
I'm curious as to the end result of this job. I know this thread is a month old but how did it turn out carving the cedar in that font and what was the final price?
Craig Sjoquist
Did you come up with layout or customer.
If customer turn it down as is and redo layout.
If you read Mike Stevens Mastering Layout.
Excuse but that reads like a book and will be worthless.
SignManiac
I know for a fact that v-carving cedar with fine serifs is a nightmare. You end up tearing out a lot of the wood, even with the sharpest bits. I personally would have explained this to the client and showed them better alternatives for material choice. Sometimes, you have to say no if the job won't work, but then again, that's why its called learning from your mistakes.
