Price check - small aluminum blanks
FatCat
I have a customer needing either 100 or 400 small 2"x6" .040 white aluminum blanks with rounded corners. These would have simple black cut vinyl applied 1-side and a 3" piece of 3M VHB tape on the back. Customer will be installing them.
I can do these in-house easily enough by cutting blanks down from a sheet of white .040, cut/weed/apply the vinyl, round the corners and then adhere the VHB tape, but the price I'm coming up with seems a little low for the work and materials involved.
100 = $3.26/ea
400 = $2.64/ea
- Each of these tags is a different building/room number, so I'm figuring in 1-hour min. for computer setup on 100 and 2 hours for 400. ($65/hr)
- Min. 1-2 hours for cutting aluminum, corner rounding and applying VHB on 100 pcs and about 3-4 hrs for 400.
- I used GraphicCALC Pro for the vinyl cutting, weeding and applying costs for each scenario.
*Would appreciate any feedback on where you'd be price-wise and if you think my time estimates are correct for the labor end.
Thank you!
I don't know, but 20% discount seems a little steep for an order this size.
With .040, you could probably round 15 or 20 at a time. So, maybe 1/2 to to 3/4's of an hour for that part and about an hour to cut out 400 pieces. Mounting the tape should take about an hour.
We wouldn't use vinyl, but flatbed print them, however using vinyl, for weeding..... about an hour for taping and applying the vinyl down.
I think your price for 100 is fine, but the 400 should be around the $2.97 or $3 dollar mark.
Doing it differently, we'd be around $ 1.80 ea. and $ 1.90 for 100 pcs.​
Marlene
are you using 10' or 8' .040?
for 100 you would use 1200 square inches and at 400 you would be using 4800 square inches which would put you into a second sheet of .040 if you are using 8' sheets. if the sheet cost you, lets say $40 for easy math, mark that up even 50% it comes out to $80 which would mean .80 each for the 100 and that doesn't include any labor to cut and round corners, the vinyl or labor to apply
FatCat
Gino, I was actually feeling I was a little low on the 100 qty, but I'm glad you responded. I'll bump up my 400 price a little closer to $3/ea based on your advice.
Marlene, just 4x8 sheets here, so your math is correct. I just hate to price that way with all the labor involved in doing these.
Crazy, but pricing things like this and contour cut printed decals drive me nuts, lol.
Thank you both!
Marlene
check with Grimco to see if you can get them pre-cut with the corner radius as with a qty of 100 or 400, it might be cheaper and then you have no labor at all
FatCat
Actually I did, and was rather shocked they quoted me $632.00 for 400 pieces and I had another vendor quote me $500+ for the same. Sadly, it just makes sense for me to do it myself in-house to save.
Marlene
wow, that is a ton of cash for those blanks. I usually check into that as it some times works but I guess not this time!
CES020
I think you are low. If you wanted to do something simple like engraved plastic, a 1" x 3" panel tag for electrical panels goes for about $4-$5.00 each, in quantity. Making them from solid aluminum and putting vinyl should be more expensive than a laser engraved plastic piece 1/4 the size.
I'd be in the $6 area if it were me. Price to the market in this case.
Marlene
seems so labor intensive. can you digitally print them onto the aluminum or know someone who can? that would cut back on some of the labor. I'd check into having them printed if you can't as it may be cheaper even with a markup on the the finished product.
FatCat
After thinking about it last night, I agree that I am a little low and am adjusting my price up slightly, but not nearly that much. If they opt for 400 tags, at $5/ea that's a pretty steep bill and even if I used Grimco's price of $632 for the reason it still seems high to me. Engraved tags seems to fetch a premium, but fewer people own engravers than do vinyl cutters. I'm also considering the competition. I imagine there are a gaggle of home based, or part timers that could easily do this for less and have nothing more in it than a few nights work and a little vinyl.
*FWIW - I usually try to end up at what I feel is a fair price to my customers vs. trying to squeeze every dime from them, at the same time certainly not giving it away. I think many keep returning because of this among other things.
FatCat
I thought about digital printing, and have a source that can do it, but cutting would be my end. If I made one goof and ruined any, I'd have to pay a premium to have those re-printed to match the rest.
This is labor intensive, but I have a new trainee I'm breaking in and this will be a perfect job for him to weed all the vinyl, apply masking tape, and apply. So I do have other motives...:Big Laugh
CES020
It's not about trying to squeeze every penny out, it's about pricing for what the market is. I'm telling you, this is not a $4 product by any stretch. I see a lot of plates and tags, aluminum, stainless, plastic, etc, and I have never seen that level of product offered for $4.
A garage shop, in many cases, isn't going to be able to make the blanks, so they'll be paying the $600 for blanks and then putting the vinyl on. You aren't competing with garage based shops here, in my opinion.
If you wanted to squeeze every penny, then I'd say you'd need to be in the $8-$10 each range. I gave you what I thought was a fair market price for that product.
Fat.......
You do it how you see fit to make money, but remember...... there are quite a few people around who can do it far cheaper, still give a good product and still make a killing on them.
Something so many around here happen to forget all the time is; technology is constantly changing, therefore bringing costs down while keeping value and quality up, thus saving the end-user money.
I'm really glad this is back here in the 'Premium' section. We can go back and forth knowing it's all for the good of everyone.
As I said, we would flatbed print an entire sheet, in about 15 minutes. Then, we could cut them and round the corners in less than 2 hours. Taping the backside, maybe an hour. You do the math..... about $65 worth of aluminum and maybe $5. worth of tape and maybe 3 man hours. I have nothing against making a killing, but in all fairness to you, not the customer, your competition will gobble something like this up for much less, if they ever get wind of a project like this. They will find a sub to produce this for them and still beat your method of production.
We have a customer where we make a 4 color 2-sided label like this, but it happens to be 1" x 5". We were getting $2.90 each and they usually got 1,200 or 1,500 at a time a few times a year. We lost the project, just this past January to someone now doing them for $2.00 a piece. They're still making a profit, but not as good as they could be.
There's always gonna be someone cheaper, but there's no need to be too cheap or too expensive.
If this was 5 or 8 years ago, you'd be fine, but too many people are staying up with technology and doing small jobs like this to stay busier and still turn a nice profit.
FatCat
CES20 - I respect your opinion, but if you read Gino's post below, I think he hits the nail on the head. We all have to be aware of the competition and different methods available to accomplish the same job.
Gino - I wholeheartedly agree 100% which is why I'm not asking more. I realize someone with a flatbed could eat me alive. I do have a source that could do these for me, but he's over an hour drive away and in the case I mess any up while cutting I'd have to factor in a reprint charge plus the time to drive out there and pick them up. I don't want to use anyone here in town because as you said - if they get wind...
Again, I'm not trying to gouge, just trying to give a fair price for the work involved.
I appreciate everyone's input - THANK YOU ALL!
FatCat
Gino, I love this line and is pretty much my philosophy behind pricing the things I do in my business. :thumb:
CES020
I agree, but you also have to avoid two things- a race to the bottom of the market, and undervaluing your product. Products have a market value. If the market value for something is $10, and you can make them for $2, making a small profit, why in the world would you sell them for $2 when the value of the product is $10. Sell them for $9 all day long.
I understand Gino's point, but it's thinking like that, that drives prices in this business down to the lowest possible point, which last time I checked, is complained about on this very forum every day.
Grandpa Dan says it like this- if you have a slow machine and you're making money, if you buy a fast machine that costs more, are you now supposed to drop your price? If a CNC routing job takes 10 hours on a slow machine at $90 per hour ($900 labor cost to customer), and 2 hours on a fast machine (2 x $90 =$180 to the customer), should you change the price to 2 hours labor now? That would mean that your investment in technology meant you made less money on the same job. There would be no incentive to invest in technology. You invest in faster machines so you can produce the same work in less time for the same pay, not so you can lower the value of a product.
I happen to agree with Grandpa Dan.
CES..... your theory is fine, if that suits you. I happen to agree with it, but not for every instance in our industry.
I'd rather letter up two trucks a week for $2,000 a piece, then 10 trucks at $400 each. However, would you rather have 90% of something or 100% of nothing ??
As far as your race to the bottom, we ALL lost that race about 20 years ago. Like Grandpa Dan and some of of the other successful shops, they are dealing with a totally different crowd then you, Fat or me. They've managed to carve [no pun] a great niche and excel at their profession. They can be super independent, where it's much harder, when one depends on whatever everyone else can do.
If I can make something and get the profit, markup, expenses, and still make a killing, just because I bought gear directed towards that very product, why not sell the heck out of it and take all the business I can. Who really cares about keeping the market at a level we can all play ?? If I can corner the market on a particular product, I will.
I knew a guy about 20 years ago who bought up all the extrusion around to the tune of several millions of dollars and made the specs to a national company to the particular extrusion he had. No one could bid against him, cause the materials weren't available. He gobbled up all the jobs and had a contract which lasted close to 3 years. So, while he didn't buy an expensive machine, he still put out a lot of money and stopped his competition dead in their tracks.
Last, if you buy a machine that runs in 2 hours what you used to run in 10 hours, no, you don't charge out at that same old price, but maybe at $ 180 or $200 an hour. You're still going 5 times as fast as your competition and making a ton more than you were.
Look at it this way, if you were running your old machine at full steam, you'd make a walloping $ 3,600 a week on that machine. If you get a new machine and charge out at your new price.... you're taking in $ 8,000. If you upgrade, ya gotta do it in every aspect of your business. That's where you and I differ. I can't say the same for Grandpa, because I can't do what he does no way, no how, so why would I compare my business structure to his ?? Therefore, why should you.... or are you also carving and CNC'ing your heart out ??
You could even go to $300 an hour [$12,000 a month] and still be cheaper than your competition, so again...... what's your objection to making more money and getting rid of competition at the same time ??
We can all co-exist, but at the end of the day..... whoever has enough money to pay all the bills and stash a little away are the only ones gonna win at this game. And it has become basically a game with so many undesirables in it today. That's the really sad part.
CES020
Gino, you don't have to have Grandpa Dan's talent to use the business model of not racing to the bottom.
I'm reminded of a shop I went to work at years ago. One guy there, that reported to me, was the slowest person I'd ever seen work. You could watch paint dry faster. After a lot of coaching and talking to him, and trying to help him along, he finally decided he didn't want to change and we parted ways. The next month, I get called in the bosses off to go over the profit and loss statements. Seems we're less profitable and he can't figure out why.
The answer. The slow guy was working on all time and material jobs. So the slower he went, the more money we made.
Same theory here. So I guess I should buy the slowest equipment on the market to make all the items we make. That way we'll make more money.
That's why I believe that all items have a market value and you should charge the market value, not some number that makes you feel good. I think it's insane to buy a flatbed printer and then race to the bottom on pricing, when in reality, 99.9% of other shops don't have a flatbed printer. So who are all these people you are competing with?
I'm not trying to change your mind or your business practices, I just find it ironic that people complain about racing to the bottom every day and then post things that show they are leading the charge to race to the bottom and it's suddenly a great business strategy.
It's not a strategy we participate in here. If it works for you, so be it.
CES.....
You missed what I said..... the industry as a whole has reached the bottom about 20 years ago. There are so many shops which are specialized, that has made this trade mostly unprofitable. Sure, some have neat niches like Grandpa and Colorado and some others here, but that's not because they go slow, not at all. It's becasue they do top notch work and people are willing to wait and pay for fine craftsmanship.... at whatever the cost.
From what I see in your post, that's called milking a job.
So, you're telling me if slow poke spent all week making one sign, it would cost about $11,546.00 ??
I'm sorry, but unless I'm missing something here.... you're saying the slower you go, the more money you make ?? To me, that sounds odd.
If I have ten sign painters here and pay each one $18.00 an hour and we can knock out 10 4' x 8' a day, that's $1,440 in labor, about $1,200 in materials and maybe $200 in overhead a day. That's maybe on the light side almost $3,000 out of pocket.... for a $4,500 take in day. Now, put in a single flatbed for maybe $145,000 and keep two guys at the same $18.00 and you now can knock out almost $3,000,000 in 4'x 8's for less then half of what you were paying to bill out almost a 1/3 or what you are now producing. But, you say, no, just keep the guys working and go slower so they actually produce less and you'll make more money.:doh:
I honestly don't understand your thinking process at all. I'm not being funny, it just doesn't make any sense when you put numbers to it and take the emotions out of it of slow=money. It never has except for schleps that milk the system or the customers.
CES020
CES.....
That's not what I'm saying at all, I'm saying that's exactly what you are doing by making things like these tags for $2 each.
I'm saying the market has a value for a product. In this case, the market value is $10 each. However, since you can do them fast, you charge $2 each. That's the part that makes no sense to me.
To be clear, I'm saying you should charge the market value for products, not anything other than that. If the market value is $10, charge in the $10 area. Don't undercut the entire market because you can make them for $2. Sure you can get more work like that, but now you've destroyed the market in your area, which I think is wrong.
We have one of the fastest lasers made. We also have one that's medium speed. If I move jobs over to the faster laser, I guess I should charge my customers less? That makes no sense to me. I'm not running a charity, I'm running a business, trying to make money and pay to live a normal life.
