Price help on store front sign
Erin
Thanks to those that helped me with the general layout of this sign. Now I'm hoping you guys/gals can help me with quoting on it.
There are actually 2 signs. The first is 155" x 25.5" in size and the second is 39" x 25.5" in size. I will probably use white plexi for both signs (unless someone has any other suggestions?). The signs are 4 colours (blue, black, yellow and white). Just wondering what some of you would charge for a job like this?
bob
Assuming premium vinyl...
The larger sign would be US$400 plus 200% of whatever the substrate costs.
The smaller sign would be US$130 plus 200% of whatever the substrate costs.
In both cases the 200% is 200% of what I have to buy, not what cuts out.
That's assuming that I could find a suitable material that's already the right color of blue. If I have to make it blue, the price goes up.
Erin
I was thinking I would use a white plexi and just lay blue vinyl down to cover the entire thing...is there a better way to do it?
Ken
Blue + yellow = green. If you just lay down a full spread of blue your yellow letters will be green when backlit. Since you have a fairly heavy black outline around most of the cut vinyl, I would try to eliminate the blue behind the text. You are using translucent, right?
The long sign is almost 13 feet. How will you avoid having a seam in the middle of the sign face?
Ken
Erin
the signs aren't actually backlite signs...there are no lights in the boxes. As for the seem in the middle of the sign I guess I didn't really think of that...
Sign Prophet
Tuff glass comes as long as you need it. Although it does have a tendency to roll up on you because it comes in big rolls.
Ken
Well, I was just wondering 'cause your are steeriing towards acrylic, usually used for a back-lit sign. You could do this with plywood then or plywood with an aluminum face bonded to it and biscuit joined at the seam or cut grooves in the butted edges and use a spline. You may get expansion/contraction issues as the weather changes. For the long sign you could also use banner material.
Ken
Erin
the store is in a strip mall type of place and all the signs that are up already are done using the acrylic so I figured I should stick with that.
Ken
I've never used the "off the roll" acrylic, but I'm betting I'm gonna haft to do that soon. East West Plastics has " roll stock" in varying roll widths. Like I say, I haven't used it but it could be a good source for you. You may want to check it out before you quote. Shipping cost could be huge to get it to your shop. Where in Ontario are you? They have a branch in Mississaugua.
Kind regards...Ken
Checkers
I won't tell you what I would charge, but I will say that I would add a premium because of the odd size.
You're either going to have to deal with a lot of waste, or a lot of headaches from having to order an odd/oversized sheet of material. If it was 24" or 30" tall, it would be a different story.
Checkers
Marlene
The boxes exist and are non-illumianted with plastic faces and there are others in the same area. Are you pulling the existing faces and replacing with new? How where the existing faces done meaning in two sections or all in one? If you are going to seam a two section, non-illuminated plastic face, I'd have the edges where the seam meets cut so they have 45 degree angles. When you butt them together, they overlap and make a less noticeable seam and better seam. If no other signs are seamed, I wouldn't seam this one, I'd get lexan as you can get the lenght needed. If you have the old faces for the boxes, is it possible to strip them down and re-use them?
Erin
ok, he's decided he doesn't want the colour background...just wants to keep it white. So here is sort of what he wants. He's not sure if he is going to go 2 colours or just with 1. I called about the sign white today and my prices are $155 for the big sign and $79.50 for the smaller one ($20 for shipping).
What would some of you price this type of sign at? How do you mark up the price of the sign white? Do you double it?
Erin
The price I've come up with is somewhere around $550 - $600. Does that sound close to you guys or am I way off?
Techman
where are u getting the numbers? Doesn't sound right to me..
Big one is about 25 sq ft.. around 25 bux a ft = $325.00 yes?
Smal one is about 23 = 6 ft $25 bux a ft = 150. Yes?
total = about $450.00
Plus if that big one is actually 13 ft them you will pay extra to get the material at full length...
Ken
Gee, I'm not sure what you mean when you say "sign white"?
Are you saying you can get a one-piece 13 feet long for $155? Is that acrylic? the other for $80 + $20 shipping= 255.
+ vinyl
+ transfer tape
(+ app fluid)
+ design time
+ consultation time
+ deliver/install?
Some may say I am ignorant of the business, but I do not mark-up materials.
My client pays what I do to get the materials to my shop.( though, figuring out which - and how much- materials to buy comes into the consultation amount..if you call that mark-up..so be it.) Materials+shipping+taxes.
With shipping and taxes you have $290 just for the sign face(s).
Have you established an hourly rate?
I know, you cannot expect your client to pay for your learning curve on a per-job basis..but there should be some factoring in of this process over the long haul. One color $ 600 min.
Hope this helps.
Ken
PS..I do like the yellow fill on the lettering ( BYRON)..it's always a friendly color. red/black combo not as effective. I think the checkered flags to the outside is better to fill the sign face and still keep a sporty look.
Techman
Why? you are losing money.. One law of economics is the oportunity cost.
You have to charge for materials because it took you time to order it, to get it, and it cost you time to write teh check to pay for it.
Erin
ya, I can get it in one piece 13 feet long. 3/16" sign whate acrylic is what they call it.
Billct2
I'd be more like $750 and I do mark up materials, you think your mechanic, electrician or plumber sells you the materials for what they paid for it?
Ken
Of course, it depends on the complexity of the job, but these tasks you mention usually take mere minutes. I'm hearing of anywhere from 40 to 100% mark-up..That is ridiculous.
Erin, thanks, where did you source the 13 foot acrylic?
Ken
