^^^What they said...
Right now, forget about GraphixCalc. The problem you have with the program isn't with the program, I don't think you know how to price anything, and if you don't know how to do it correctly, a program isn't going to help. To use Graphixcalc, you have to know what the price should be already. So put that on the back burner until you have a full grasp on pricing and can do it on
paper.
At the end of the day, you have to know how much it costs YOU to produce a
sign. I mean every nut and bolt, not just the vinyl and the plastic. If a
sign takes you two hours to make, you have to know how much those two hours cost you... how much was the water bill for those 2 hours? The trash? Electric bill? vehicle payment, gas, maintenance, advertising, legal, accounting, subscriptions, etc etc etc.. You need to write down every single penny you spend on overhead expenses for your business in a month and divide that by the number of billable hours you can realistically squeeze out of that month. If you overhead for the month is $2500 and you realistically can work 80 billable hours in a month you need to clear about $32 per billable hour to break even and not lose money into the overhead abyss. Remember, a BILLABLE hour is not any hour. If you're sitting around on
Sign 101, taking the trash out, cleaning the shop, doing paperwork or taxes, or any other task not directly related to the manufacture of your product, those are not billable hours.
So step 1, you need to sit down and spend a couple hours totaling EVERYTHING up that costs you money to run your business but isn't directly related to materials in the product. EVERYTHING. Then you need to take a good long hard look at really how much time in a month you can actually make your product. And don't say "I can work 24/7, so I can have 720 billable hours in a month" because you can't. You're the owner, sole employee and janitor. I'd start at 20 hours per week at best, and I'd bet money that's even high when you really stop and think about it. So figure this out and you're well on your way.
Step 2, know exactly how much time it takes you to make your product. For the next year, keep a running spreadsheet of how much time in minutes it takes you to make EVERY SINGLE THING YOU SELL. I don't care how long the list is, do it. At the end of that year, devote a couple days to figuring out the average time it takes you to make a coro yard
sign, a banner, a decal, etc.. You'll be surprised at these numbers.
Step 3, just like above, for a year, track exactly how much administrative time you have in each of those jobs. From the time it takes you to meet with a client to the time it takes you to bill it, receive the payment and deposit the check. Use these numbers to determine the average amount of non-billable hours you have to devote to any job. You'll be even more surprised at these numbers.
So now, you just learned that to make 1 coroplast yard
sign, while you may only have $7 in raw materials in it, you might have 45 minutes in it including design and production, and you may have 1.25 hours in administrative time in it. If you're currently pricing things on materials plus markup and labor, and you take your breakeven $32 hourly rate times .75 hours, you come up with $38 for that yard
sign (assuming you doubled your materials). But guess what, you just lost your ass. Those 1.25 hours in admin time cost you money too, $30 to be exact, So subtract that $30 from the $38 and you're left with $8, , less the $7 in materials and you made a $1 profit for 2 hours labor. $.50 per hour is not a living wage my friend.
Knowing this, you need to figure what you real hourly rate should be. You know that it costs you $32 per hour to keep your doors open. I would double that, make it an even $65, this allows for wiggle room in time, and allows for a profit and paying you a fair wage. Now, take your materials, I'd triple them, double isn't allowing for any screw-ups or wiggle room, if you mis-cut your coro, you just lost money.
So with your $65 hourly rate and your 3x markup, let's reprice that yard
sign:
materials: $7 x3 = $21
time: 2 hours x $65 per = $130
Total cost for you to sell a single yard
sign and make a fair profit = $151
Holy crap, who's going to pay that for a single yard
sign? Nobody. Now you've got to set a shop minimum and stick to it. Figuring out a shop minimum is difficult because things vary so wildly, but you basically need to figure out a price at which you know anything below will lose you money. If you average out your smallest jobs and find that you can't produce any job in less than an hour, your minimum needs to be at least your hourly rate plus some to cover materials. I'd say $100 is a good start. It sounds ridiculously high but when you work alone and you have nobody to spread the work around to, you have to be covered. Efficiency comes into affect here, if you can streamline your processes and get times down, you can lower your minimum. For example, our minimum is $45, our shop rate is $95. The reason we can do that is because I have 8 employees that can absorb that small job with no problem. Our processes are sickeningly efficient as well. A one man shop has to grind to a halt to produce the same job we can produce without batting an eye, simply because we have the manpower and processes in place to move it along from point A to point B without it interrupting anything else.
So, it's critical that in addition to everything else, you learn to work with efficiency at the top of your mind, always. And I do mean always. Never, ever ever do anything without trying to figure out how to do it more efficiently. That doesn't mean cut corners, it means figure out how to achieve the same end result in half the time.
If it takes you 1.25 hours in administrative time to sell 1 yard
sign, it'll take you 1.25 hours in administrative time to sell 100 yard
signs. If you've been tracking your production times accurately, you should have figured out a sliding scale for how much time it takes you to make multiples. If it takes you 45 minutes per yard
sign, find another job. In a run of 100, you need to figure out an efficient method of manufacturing them so you get your production time down significantly. I'm talking 2-3 minutes each.
So now, let's price 100 yard
signs:
materials: $7 x 3 x 100 = $2100
time: 4.6 hours including admin and production x $65 per = $299
total selling price per piece: $23.99 ea., total profit: $1549.50, or $336.85 per hour. You can live on that.
So is that making sense? Pricing has just as much to do with the administrative end as it does with materials. You have to take it all into consideration. And efficiency is key in everything. You have to learn that your time is money. I read a lot of your posts complaining about having to drive 30 minutes to and from a meeting with a client for a single yard
sign. Dude, you've got to take that into consideration. You need to learn to start prequalifying leads before you go on wild goose chases. Don't randomly drive all over the place in hopes you'll sell a yard
sign. Don't randomly drive anywhere unless you KNOW you're going to walk out with a sale and a sale that is going to cover that drive time. Ever.
So answer me these questions:
How much time do you spend on a single yard
sign, including the time to sell it?
How much time on a 3x8 banner?
What is your currently hourly rate and how did you arrive at that figure?
What is your current overhead, and how did you arrive at that figure?
How do you currently price a job (honestly)?
