Pricing Help Please.
D & R
We just did 2 backlit faces, each 60"x80". spent about 8 hours removing old vinyl and prepping the surface for new vinyl. on each face we used 2 yrds of 24" vinyl, 3 different colors of translucent( 6 yrds Total Per Side) we also installed 4 5 ft. long zip tracks for changeable letters, (Per Side)There was no install, they were dropped off and picked up by the customer.
I came up with $ 920.00 am i way out of line?
Thank Dave
Not to sound insensitive, but if you can’t clean the faces faster than that, it would do your client, your reputation and your project time table a lot of good if you would’ve just gotten new faces.
I have no way of telling if the job should take that long due to… hard to get off vinyl, excess copy or just plain slowness on your shop guys, but charging someone eight hours for something like that is not a good idea from a professional standpoint.
Everything from scratch would’ve been:
Faces about $250 total for two pieces of 3/16” modified.
Around $90 for your translucent vinyl.
Your shop time to lay it out apply it… 3 hours
8pcs track for .060 is around $24.
Installed another hour.
You do the math. :rolleyes: Going on your hours doesn’t give one anything to go on, other than you did something wrong. Whether your cost of living is the same as mine or not, has no bearing on doing a job in the wrong manner. If I can do the same job in three hours with the same costs, you shouldn’t have to get 14 hours to do the same thing. You’ll eventually start to lose customers if you justify doing things this way.
I think your $920. is more than a good price for ‘that job’. You didn't have to pick it up or deliver it. Your using the wrong methods to get the finished results is a lesson learned and worth much more than a dollar amount.
D & R
Thanks For your Response
Just to clarify i did advise the customer it might be cheaper to just replace the faces than to spend all that time to clean them but thats what he wanted to do. so thats what we did.
Thanks again for your input.
Dave
DPD
You quoted a lower price for "all new" and he didn't take it? He told you he wanted to spend more money to keep the old stuff?
Your customer has some quirkiness in him.
If I'm redoing a face I always opt for replacing the entire shabang - it works out to less work and more profit for me and the customer gets a better deal. I probably would've asked him (in a nice way) why he was doing something that didn't make sense.
