Not to sound insensitive, but if you can’t clean the faces faster than that, it would do your client, your reputation and your project time table a lot of good if you would’ve just gotten new faces.
I have no way of telling if the job should take that long due to… hard to get off vinyl, excess copy or just plain slowness on your shop guys, but charging someone eight hours for something like that is not a good idea from a professional standpoint.
Everything from scratch would’ve been:
Faces about $250 total for two pieces of 3/16” modified.
Around $90 for your translucent vinyl.
Your shop time to lay it out apply it… 3 hours
8pcs track for .060 is around $24.
Installed another hour.
You do the math.
Going on your hours doesn’t give one anything to go on, other than you did something wrong. Whether your cost of living is the same as mine or not, has no bearing on doing a job in the wrong manner. If I can do the same job in three hours with the same costs, you shouldn’t have to get 14 hours to do the same thing. You’ll eventually start to lose customers if you justify doing things this way.
I think your $920. is more than a good price for ‘that job’. You didn't have to pick it up or deliver it. Your using the wrong methods to get the finished results is a lesson learned and worth much more than a dollar amount.
