Repainting or Replacing a Sandblasted sign - prices?
Big EZ Signs LLC
Howdy all,
So I have another bid, this one for a 24" x 42" sandblasted sign. The owner wants me to provide a bid for:
1) Repaint, reseal, and rehanging it.
2) Replacing it with a new HDU sandblasted sign.
I'm completely clueless on how much to charge to repaint it, but the Signcraft guide suggested anywhere from $601 - $782 for a replacement, depending on if this is an "Intermediate" or "complex" design.
Suggestions?
Doyle
I wouldn't even offer to repaint it..... but if I did, I would give no guarantee at all. It looks pretty weathered, the wood has probably started to rot, and it looks like the wood panels may be separating. I'm not a sandlbasting pro, but I would say that this sign has served it's time and needs to be replaced... JMHO
Doyle
and I also wouldn't re-hang that thing either, you may be held liable if it finally gives out and falls on someone's head!
Although your photos are a little hard to tell the true condition…. the sign looks fine. Take that dumb aluminum cover off of it, put it through a drum sander as is, re-glue it, clamp it for two days, putty up voids, reseal it, prime it, paint it and it should be alright. Probably cost about $750. Can you do a new one in wood for that ?? Probably not. In HDU probably around $900.
Good Luck....................​
Doyle
<b>
</b>
Blueridge Fabrication can! Depends on how much work YOU want to do I guess
Craig Sjoquist
if thats redwood ... or some other good wood for outdoors.... repaint would be my best guess, ...but would 60% about of ..cost a new
since repainting is a little like tossing the dice...
selling improvements comes to mind from ...frames & post to landscape
git r dun
Yeah, they probably could…. however, that wasn’t the question. Anyone will make far more money if they do the repair work in-house. If you don’t have those capabilities, then the question would be posted differently. I guess since we’re a full service shop, I don’t consider always getting everything done somewhere else. Til you would add removal, packaging, send to any other shop to do the work, pay their prices, and shipping back, paint it and decorate it and then re-install it…. I doubt you’ll make much money at all. To replace a wooden sign with HDU in my opinion is a crime.
The OP has many options, but should he/she care to farm the whole thing out, then there are things to think about. Most wholesalers use pre-fab blanks that anyone can get anywhere…. USA. That’s a cost [less an unneeded mark-up] you could keep in-house. Look for a local blaster and you got the job now…. almost completed in-house. The difference with our shop is… we hand pick our redwood and/or cedar blanks and use clear/heart, all vertical grain wood and glue it up ourselves in-house. You are getting a truly hand-made sign…. not something built by a machine with 3” and 4” pieces of lumber. Ours are all from 12” board foot 6/4” or 8/4” stock.
Should someone need to farm the entire job out, then your suggestions will make more sense. Had the OP had in mind farming it all out, then they didn’t convey that message.
Big EZ Signs LLC
I can repaint/repair in house, done it before on Sandblasted signs, but I've probably undercharged for them.
For a new one, I've got a local blaster lined up who would do it for less than $50.00 ( don't laugh, really ), and I'd decorate it. Just need to find a source for the blanks.
Gino, I know using HDU instead of Redwood or Cedar seems a crime, but my thinking is, you do it in #30 HDU, and they never have to replace it again. Well, until a car hits the monument wall....
SignNutz....
I think you're doing the right thing here. Getting the substrate and lining up a blaster. You'll make a ton of money on this keeping almost all of it in-house.
We've made lotsa HDU signs, I just don't like them.. so we don't push them. You could probably get a wooden blank to your specific size easier than the HDU.
Big EZ Signs LLC
Well crap, looks like I overbid???
my bids were:
$380 for a repaint
$605 for replacement sand blasted cedar
$1090 for replacement sand blasted HDU
She said my bids were more money than the Homeowner's association had in their treasury, and that they had found someone to do it for cheaper.
So did I overbid?
Letterbox Mike
I'd say maybe overbid a little on the HDU, underbid a little on the cedar and it's hard to say on the refurb, not being able to see it in person. Judging by the pictures, probably should have been higher on the repaint, but just too hard to tell. All in all, none of the prices are out of line at all, off by a hundred bucks one way or the other at most, at least from what we would charge. You did fine. Nothing to lose a bid over, they just found a lowballer.
