Roland vs 640 Ink Configuration
vondegroot
bad design kills
I figured it out, I just unplugged the ink pump motors and slapped some lam over the ink cart chips :) Fun stuff!
ezequiel
printer desing
A question, does anyone know if double white lines are faster than single metallic lines?
CMYK-Cl-Ml-MT-W or CMYK-Cl-Ml-WW
S2DZ
Hello, we have a vs-640 and we ll change ink configuration from CMYKLCLMWMt to double CMYK. As the 2 channels of W and Mt are clogged(tubes, dampers, recirculation pumps etc) , does anybody knows if we can bypass these pumps and install 2 new channels like the 6 standard ones (CMYKLCLM) ? Ps We ll also change the printhead to a new one as its also clogged.. I attach the diagramm (the last 2 to become like the other 6 without pumps/joints etc)
Thanks a lot for any future help!
Hi,
did you make the bypass? I am dealing with the same problem.
Fantazia
Wonder why none has converted 8 colors to 6 colors with double cyan and magenta. Lines are the same, only white and metallic swap to cyan and magenta. There are many owners of VS that run them with cleaning cartridges for long time now.
cornholio
Because these printmodes don't exist. It's not possible to drive the ink channels individually, as it was possible with older Rolands with DX4 heads.
Of course you also needed a full blown RIP with profiling capability and spectro...
But it was done for gamut enlargement with special colors or different black densities for gray scale fine art prints back then.
T4rb6
I have a Vs640 CMYKcm WM converted to CMYKcm with CCMM work good for year and you can in submenu disable the double CM if you have probleme with the old WM lines ... (disable alternation menu)
Reactions: 1 users
i may be wrong but i think it would be possible with flexi 24. you can do custom ink configurations
i am upgrading to flexi 24 this week, but, not sure i have any hurry to experiment with this.
i like the idea, but, realistically, i will be making all new profiles for all the materials we print on, then i would have
to deal with getting all my printers printing identically.
maybe i will wait for someone else to try it first....
andrewserkov
Please also send one to [email protected]
also a question. are SL-cl cartridges strictly needed for making a transfer to 2xcmyk? I will replace all the tubes and a head because of a long period of staying without any printjobs (and the head had been already dead since the former owner). I used it only as a cutter.
Thanx
cornholio
You don't need the CL cartridge. Just unplug the pump, put a tape over the chip contact of a color cartridge and do the pump up procedure.(it takes a while)
Reactions: 1 users
SMNR
So how should I proceed for that? Currently have 7 colour (double white) and have quite a few extra CMYK carts. Don’t mind wasting some instead of buying CL carts.
Could I just put CMYKCMYK in with tape over the chips going in the LC LM and W channels and pump up until the proper colours come through and then reconfigure the printer for dual CMYK?
vondegroot
bad design kills
Also wondering if this is the smarter way!
I'm wanting to go from from CMYKlclmlk to Double CMYK and cleaning carts are even more $$ than ink!
And then maybe just doing a damper change after the change of there's any issues.
Hope someone can chime in!
