My boss acquired a used flatbed printer, large format printer, router/plotter and some other general support equipment from a close-up. I am tasked to put them altogether and try starting a new business from it. We only have a rather small rectangular area of about 1200 sq ft. I am soliciting some comments and feedback from fellow forumers here on how best I should renovate the working place to make the environment both functional and pleasant:
1) Should I install a false ceiling? What is the ideal height? My current concrete ceiling is up to 12 feet high.
2) Should I install air-conditioning or just use ceiling fans or a combination of both? Aircon might make the air unhealthy due to the solvent etc but fans might cause the equipment to function less than optimal. The outside ambient temperature at my location is a hot 30 deg C with humidity as high as 90%.
3) Is it advisable to install a ventilator to suck away the “poisonous” fume” esp. from the large format printer which uses solvent inks?
4) Should I place the router in a separate enclosed room as this process might be too dusty? I'm afraid it might contaminate the other print processes if I don’t segregate them. But doing so might hinder movements from one process to another since the total work area is small. Maybe a dust collector is required for this process?
5) Is there any special lighting specifications I should follow so as to visually inspect the print quality better? Or, is brighter the better without being too glaring?
6) What about colors on walls and flooring? I plan to whitewash all walls to give a brighter look and lay homogeneous floor tiles for cleanliness and ease of maintenance. As for the flooring, I like to show off the creative part by opting for black and white colors, arranged like a checker board. Problem is, I do not know how dirty such printing operations can be on a daily basis so the while tiles might get stained easily from the ink droplets etc.
7) What about the storage racks? Should I purchase those cantilever type or heavy duty horizontal racks for a range of media and materials?
Any feedback is much appreciated.
