sign face question
gabagoo
I am building a sign face using ex12 extrusion. How much bigger than the acrylic does the finished frame have to be to allow for expansion and contraction? This one is just a frame with no box and is about 12' x 30". Would 1/4" be enough?
Z SIGNS
1/4" should be good enough.
Knowing how much something will expand and contract is important especially when joining dissimilar materials.
Most sign materials like acrylic come with a spec sheet that has all the physical properties that list expansion and contraction.
Billct2
Maybe I'm misunderstanding, but if the face is 1/4" smaller all the way around that means the face is cut .5" shorter. Doesn't the face sit on the bottom of the frame? So the 1/4" may be distributed evenly on the sides but on the top its 1/2"(unless you're using a hanger bar)
S'N'S
I agree, I would have thought 1/4" on top and 1/4" on one side would be enough.
You'll still have an inch behind the retainer lip, but I agree, a 1/4" all the way around is a little sloppy. 30" × 144" shouldn't be too bad, but I wouldn't make that my rule of thumb.
