Stained Glass Look
psbc2009
Customer wants a stained glass film applied to their windows. Is this something you would print possibly, or are there products that acheive this look that are ready to apply. Any thoughts or material suggestions appreciated. Something new every day.
Pat Whatley
Translucent vinyl with black for the "lead" between the colors or digitally printed on clear. The digital print doesn't have the depth of color of the vinyl but is easier.
psbc2009
I was thinking of finding a pattern, printing it on clear, lam and install from the outside -or using customer design if they have something in mind
Farmboy
We've printed a few on 210 lam and they came out great. Customers loved the look. You just have to watch your heat settings.
Billct2
I did this fake stained glass for this pub. I also did some replica stained glass for inside that was much more detailed (and also backlit). I created custom fills in corel (if I didn't have to match the existing glas I would have used one of Fred's fills) then printed them on clear and applied to beige plexi. They were hard to tell from the real ones. I'll se if I can find a pic of those.
sfr table hockey
I like that, those letters look like the real deal. What did the beige plexi do that you could not do by printing?
Just wondering.
Billct2
The beige toned down the illumination giving it a softer older look.
Here is a fill I built to match the existing glass inside . I put duranodic vinyl stripes on
for the leading after printing. Wish I could find a pic of the finished job, it looked pretty good.
sfr table hockey
Yet another on the list of things I want to try.
Thanks for sharing. Simulated look is one thing but when you can't tell the difference..... that is too good.
Rooster
The dreamscape glasstex film is a printable textured vinyl that will give your simulations a little more texture than a regular flat clear laminate applied over glass will.
Sticky Signs
We do stained glass for the film industry all the time. The file is usually created in photo shop with the "led" included and some modelling in the colored areas. I print double pass on clear. Stick the vinyl to glass or plexi. Than we use real led tape to cover up the led lines. We than use a two-part clear resin to cover up the graphic. We mess around with the resin so that it dries with some texture to it. It's a long process but it always looks great.
This photo is from a set on Smallville.
