Stuck...
cgsigns_jamie
Well this is my first time posting for logo help so please be gentle.
This is one of my best customers and she want's a completely new look. She just started a new business, LiveWellMD, with a logo designed by someone else (not sure why she didn't use me) and she wants to update the look of Pointe Med.
So far this is what I got. Not really sure about it, seems kind of blah, I think it's the font but wanted to ask the "experts"
Thanks in advance...
iSign
there's a number of things i don't like about it, so I'll start things off here with the first few that bug me.
Don't forget to kern your work. It's bad enough to let a sign go out with typing right out of the box... but a logo with big irregular sized gaps like your secondary copy is not cool.
The oval thingy is too low in my opinion. If it's going to drop below your 3 line name, to fit behind your secondary panel, I think it should at least rise above the three lines a little bit. Because it's highest point is just in the center, like the way "O's" are taller than "E's" so they don't look smaller... this ribbon thing needs to at least look even instead of low... but I actually think it would help if it was much taller.
also don't like the way the ribbon gets wider and more narrow, and changes color... I think it should do all those things, but I don't like the way it does, because I want it to look like a twisting of a 2 sided, 2 colored ribbon... which it doesn't look like, it looks more like a failed attempt to represent a twisting of a 2 sided, 2 colored ribbon.
Lastly, I think the stethoscope looks like a cheap piece of clip art, stuck in a logo. Even if you drew it, it looks stuck in there, and it looks cheap.
On the plus side, I think the logo will look good to a lot of clients already, so it's not bad looking, it just could be better, & I know that's what you want too... so I'm just trying to help.
cgsigns_jamie
Thanks for the feedback, that's exactly what I was looking for. I didn't really want to do the circle/ribbon but she want's it to tie in with the LiveWell MD logo (it's on the website) and they like it. I think I may just try something that I like. I didn't even notice the kerning until you mentioned it. I'll post revision 2 soon.
cgsigns_jamie
We were thinking the same thing but didn't think it would go over to well. She has a sense of humor but I don't think that one would fly.
Craig Sjoquist
your 1st one was dated indeed ...thinks it could be greatly improve if ya down size the name a bit, make isigns suggested changes to oval etc., ...giving more air space would be a great improvement around whole layout
your 2nd is a good start ... there again air space around whole lay out , and name does look crowded, some color change more conservitive or lively
git r dun
cgsigns_jamie
Thanks guys for the suggestions. I think I may just tweak the first design. I just don't get that warm and fuzzy feeling with this particular job. I may just take iSign's suggestion and add a "PMS" monogram inside the oval ;-)
Is it possible to see where this came from as far as what the other logo looked like and how you get your feel for this one ??
Murmanation
I was looking at the website, did you work on that? Just curious, it would appear there are some similarities between the logo you are currently working on and the LiveWellMD logo.
Is she wanting some continuity between the two business logos? Because if so you are certainly giving that to her. Not to say that is a bad thing, because continuity can be a plus but not all business owners want that. I work for someone that owns two businesses and they want the same two colors and similarities between the logos. I told him that he should just combine the two if that's the case but I got reminded that I don't get paid for those ideas haha.
I like the first one better with some ideas: I'd take the stethoscope and make a 1 or 2 color image out of it with either Live Trace in Illustrator or something of the like. Maybe do the ear tubes in blue and the listening cup in green. Also, the bevel/emboss thing you did on the tagline isn't necessary, it's confusing to read. I do think you are off to a great start though.
cgsigns_jamie
Yes both companies are hers, she just started the LiveWell MD, I had nothing to do with the Logo or the site (I wouldn't tell you I did that site even if I did). That's why I was trying to do a variation of the circle so they will look like they are in the same family. That's basically what this is a family of 4 different businesses. Now that she started the new LiveWell she wants to update the look of her two older companies (neither of which ever had a logo) the first of which is Pointe Med Services. I will be sure to take all your great ideas in to account when I post revision 3 later today.
Thanks again for all your help!
Murmanation
I like it, you're getting there. I still like the idea of doing some sort of 2 color vector version of the stethoscope, but good work. Also, you might show the customer one without the tagline just for a "logo" and add the tag for cards and signs.
