rjssigns
If youre doing that many cut throughs why go with a summa? The cutting strips on these machines need to stay flat and even or you'll get spots that don't cut through properly. I know the summa has a stronger strip than a graphtec.... But if you're cutting through so much... Your strip is going to constantly need replacing.
We do roughly 30,000 decals a month on our graphtec and no issues...all perf cut.
Keep in mind paper dulls blades really quickly. So cutting through paper you'll go through quite a bit of blades. We use cheap $1 blades for our perf cutting... They last a week or so at the above volume, but at a buck a blade it doesn't break the bank.
I don't have a summa, and I have very little experience with them. Each machines have their benefits... But I believe at this volume.... Perf cutting via a Channel and not destroying your strip is likely the best option. Bring some material to your dealer and see how the graphtec cuts though. With the benefit of the channel... Comes some downfalls. You have to swap blade positions... And it is a bit slower at perf cutting. But we can load a roll on ours, send the whole roll through with the press of a button to do a kiss cut.. Swap it around and send the whole roll again to do perf cuts. It takes maybe 15 mins of manhours a day to cut a whole roll kiss and perf.
Nice! Real world experience at the same throughput as the OP but with the proper equipment. Can't argue with facts. Buck a blade is crazy cheap too.
