Boudica
So, we've got a new plotter! While i have been able to do simple kiss cut jobs with it, I am having a heck of a time dialing in the Perf (flex) cut feature. There is this whole testing set-up procedure, I walk through it, make adjustments, everything seems fine. in the full pressure test it cuts all the way through as it should. When I actually go to cut the job, it won't cut all the way through - not even close. Or it will cut all the way through one side of a square shape, but not the other 3 sides. The length of the full vs flex force seems right (10mm and 1.2mm). However, when it's cutting it's not doing a perforated line - just a solid line that still isn't cutting all the way through.
Is there anyone out there familiar enough with this machine that you can tell me what I'm not doing right?
