Need Help Summa T750 SL plotter will not connect to plot
Angela Nowling
Hi, I am having trouble getting my summa T750 SL plotter to cut. I use flexi-sign design software and it is not on their end.
This just started happening after a microsoft update April 16th. Can anyone advice help on this issue?
I appreciate any suggestion and if this plotter is outdated and maybe I should consider another option.
Hi Angela,
How are you connecting to your computer? With USB or serial (9-pin) connection?
FrankW
You should re-install the USB-Driver from the summa Website. You can check the connection easily with the software Summa Cutter Control available too from the summa website (for that old machine, use the legacy-version of Summa Cutter Control).
  • Agree
Reactions: 1 user
Angela Nowling
Hi, either way is fine. I'm not the most tech savvy, so screen share would be great.
Text me at 713-614-9465 and I will call you back when convenient for both of us, Thank you so much!
Angela Nowling
Thank you I will try that.
netsol
you would think after 40 years microsoft would get good at this.
you would be wrong
do a system restore, go back a week or so before the problem reared it's ugly head
off the top of my head i don't know which microsoft update caused this.
FrankW
USB-Cord or the USB-Port at the PC or the Cutter. Hopefully not the USB-Port at the cutter, because there are no spare parts anymore.
Angela Nowling
Good Morning Frank, Thank you so very much for all your advice. I did all you said, connected with serial connection and it is working now working. I can't thank you enough. :)~Angi
  • Agree
Reactions: 1 user
