Temporary Daily Sign Cover Up
Ultimate13
We have a customer looking to cover up 2 drive thru signs twice a day. The current signs are 30" x 30" aluminum with rounded corners mounted to a pole. The signs they want to have made will cover these and be installed and removed twice a day. Also in an effort to not destroy the current signs of course.
Any thoughts or ideas on how to do this successfully would be great, thank you in advance.
Texas_Signmaker
Very Active Signmaker
Are they changing the words on them or just blanking them out? Any other info you can provide so I can picture this better?
Ultimate13
They are basically changing an exit only sign to say drive thru during busy hours so they will have 2 lanes for drive thru. It will have text on it and cover the entire sign or large enough to cover the existing text.
ikarasu
If it's only during business hours, and theyre not worried the sign would be stolen... I'd just do Aluminum panel or plastic like this -
Easy enough to throw on when they need to or take off. Also easy for a customer to grab it while walking by... But sounds like they only need it during open hours, so it might work.
Could always drill a hole on the bottom of both and use a padlock if need be... Not as pretty though.
GAC05
Quit buggin' me
Make them out of one of those lightweight poly/aluma skinned panels - put a small 'U' channel extrusion on the backside, top & bottom, so they can slide it on and off. Would have to check for clearance on the pole but there is usually a small offset.
Reactions: 1 users
Big Rice Field
Electrical/Architectural Sign Designer
I know they are probably cheap customers, but the ultimate solution is to make an electronic message center type pf sign where you could program the display copy.
