Trucking Company
neato
This is for a local guy with one truck.
Sorry, that's all the info I was given too. :(
Any suggestions? To boring?
Jackpine
I like it. Maybe a lighter color somewhere or an inline in white on SH. The maroon and black are pretty clos in value....but a good layout.
vid
I like it... If you want to add some texture to the logo, you could do an upside-down Mayan pyramid (as opposed to an upside-down Egyptian pyramid) in the background... Carry the color from the oval into the "pyramid"/wings looking background.
Hopefully you'll see what I mean with the attached sketch.....
ENTDesign
The ampersand doesn't look right to me, doesn't seem to fit (by my taste, for what it's worth).
I like the wing look better, also.
Any one of the layouts can work. The colors, though, instantly bothered me, and I think (not sure).....it is the amount of black around the S&H and the red between the yellow and black.
When I say "bothers", in this situation, it blurred.The layout is good. I am a wee bit partial to triangles, vs. wings
Bassbum2
The logo looks nice but I agree with Mike Paul, the H looks funny, kind of like a I and a T laying on its side.
JMO
ovrcafnatd
Hey there Neato
I like the bottom one myself....the one with the wings, but lighter coloration.
I'd work on the colors a bit more. Just something about them - they kind of all get lost into one another.
I agree with whoever said the ampersand doesn't belong...just something not quite right with this heavy block text.
Nice layout
Dave Drane
Neato, first off, nothing you ever come up with is boring. I like your original design, but maybe instead of the warm colors could you have a look at a prismatic letter done in white/off whit and lite greys?? Just my 2¢
timmay
Definitely like the bottom one - the black around the S H still seems dark though - think if that' was lightened up, outlined, something... you'd have a winner!
geedub
is it possible to change the font of "trucking"?
I mean at first glance it is hard to decipher whether or not it says trucking or trucking minus the tr add an F
Great Start
Okay, we'll just move right through this.
The ‘H’ looks like you added serifs and then took some away. Personally, and this is a personal call on your part, but I like the triangle more. The ampersand is a problem. As others have said it looks out of place. It kind of looks like it’s just floating across the letters, almost as if it doesn’t belong. Could be that you have heavy shadows on the letters that it’s locking together and nothing behind it. Give it some stability. Your choice of fonts is interesting, but they work, even though you have four items, each with a different font. That’s kind of frowned upon, but if you like it… go for it. Last, and probably most important in my eyes is your use of colors. I like to design in black and white. That helps get your graphics, fonts, gingerbread and so forth all well balanced and stops you from disliking a layout combination because of poor color choices. I’m not saying you have poor color choices, but you have kept almost completely to one side of the color wheel. That will tend to make anything boring. Nothing pops. Unlike some of the designs I’ve seen here and other places in my time, most people tend to use sensory overload as their profile for color choice. Something [usually the main idea] should be in the front while systematically pushing everything else back, a step at a time. This is accomplished by font choice, stroke, shadows [or other effects], but most of all color. If everything stands out, that’s like five people yelling at you at one time. What do you do, you turn away and look for someone else pleasant to talk to. Well, your sign does the same thing. If it creates so much tension, the viewer will probably read and not remember too much of what he/she just saw and turn to the next easiest thing to read and remember that one instead. Play around a little, it has really good potential, and I’m sure you’ll like it when you put the finishing touches on it. Now’s the time to experiment.
Good Luck. :thumb:
vid
neato said:
What about something like this?
You're already at the top of the class with your work. IMHO any critique beyond what you've posted is just food for thought. It comes down to how much time you want to invest for the dollar return.
It seems like you're at a point if you change too much the dominoes will start to fall. Changing the ampersand will make "Trucking" look out of place, because it won't share the relationship in typestyle.
If you go that route, I'd think you'd need to make the oval smaller and have "Trucking" extend beyond the oval borders. That way it would be grounded against the white space. Maybe bump it up so that it overlaps the S&H shadow to hold that together, too.....?
Serifs on the right side of the H would help to visually hold the S&H on the wings and oval.
...........and maybe some SignGold MiraGold instead of the orange? buuuuuut, then you might have to change the yellow, too.
I like both your original and the bottom one of your last post (w/the orange wings) because of the contrast. I like the way you mix up your color palettes, it keeps your work fresh.
annnnnnnnnnnnnyway, very nice work --- as always.
neato
Wow. Ricks post has really made a difference on these critiques. Cool!
Thanks for the suggestions everyone. I've played with it a bit more. One with more contrasting color and one with less...
