Vinyl that won't curl
bob
Does anyone know of a vinyl that when printed and contour cut with a full bleed can be depended on not to have the edges curl up where the full bleed was cut? Over the years I've tried a number of different products and had some successes and some failures but I don't know of a vinyl that I can be assured won't curl. I've had both good and bad experiences with Avery 1105 lots of initials, 3m high end something or other metallic, Oracal 3751 no initials, and others long forgotten, but none of these can be depended on not to curl.
Is there some secret stash of non-curling vinyl somewhere? Or is it futile to look?
  • Agree
Reactions: 1 user
Not sure if this will help, but the proper laminate is supposed to prevent that from happening.
How much time is elapsing from instal time to curling time ??
Is it facing south or close to it ??
I've had some of the cheaper egress vinyls work, but not if it's dark colors.
  • Agree
Reactions: 1 user
dale911
President
If you print any vinyl with solvent and don’t let it outgas long enough before cutting, it will curl right off the backing paper. The higher the ink load, the worse it will be. I have even seen this happen with high ink loads of latex. No problems with UV cure inks. If you let it outgas long enough and this happens after lamination, you probably have too much tension on the laminator. The cuts then allow the extra tension in the lam to pull the vinyl up.
  • Agree
Reactions: 7 users
SignMeUpGraphics
Super Active Member
It also depends on ink load and drying times. We use a very cheap LG monomeric for labels. We cut through full bleed 320% print all the time. As long as we let it dry 24-48h before cutting, we don't get curling.
  • Agree
Reactions: 2 users
Boudica
we generally use Ij35c-10. Let is out gas for about 48 hours, and make sure there is no heat involved when cutting.
  • Agree
Reactions: 1 user
CanuckSigns
General formulations 6 mil semi rigid vinyl, guaranteed not to curl, and thick enough to not need laminate for decals and such. It comes in permanent and removable adhesive.
  • Agree
Reactions: 1 user
midnightmadman
Old thread but rather than start another I was wondering, if curing happens has anyone come up with a method to keep the vinyl down again permanently?
Boudica
Do you not understand the question?
I understand your question, I was being facetious - hence the "big laugh" emoji.
I don't know of anyway to keep curled edges down short of sticking it on to something, or maybe using transfer tape (overkill, and not even sure that would work). If it's calendared vinyl it may just relax on it's own with some time.
Boudica
Was this not about vinyl that curls after installation...
hah, maybe. I didn't re-read the whole thread, I was thinking this thread was about vinyl curling after cutting it too soon.... I must have been thinking of a different thread.
Sorry everyone. I'll see myself out.
midnightmadman
Thank you. I may try that actually
Like to send you Photo Tex polyester adhesive fabric that you could full bleed contour cut without curls. email me [email protected] I can send you a free sample.
ikarasu
If it's curling before sticking it... You can stack them and put some heavy books ontop overnight and they'll lay flat again.
If it's curling after sticker... Could be a few things. Too much tension on your laminator stretches the laminate and causes curling... It'll try to lift and cause the edges to lift as well.
You're supposed to always post heat the edges of material after install to ensure it gets a proper bond... It takes time and isn't needed with most things, but the 3m course actually tells you to heat every single edge on walls or vehicles, while it seems like overkill for most items, we've found the ones we do it to never have edges lifting.... So we've started to do it on pretty much everything. Takes 5-10 mins per install, so it's worth it.
If you're using a Calander laminate on a cast vinyl that causes curls as well..
Last issue could be just cheap vinyl. 3m / Avery is expensive... But they've nailed down adhesives, I think all cast vinyl is created equally... But the adhesive on the back of the vinyl is what makes or breaks an install. The cheapest decal / vinyl we use is ij40.... We pretty much never have any failures or shrinkage.
somcalmetim
never had 3M IJ180v10 with 8519 shrink or curl, even sitting unpremasked for years...no problems with 3M 40c either as long as you laminate it with its matching lam...I let it dry overnight but never had curling on quick reprints either...
Things that will cause curl in finished material...
-too much ink
-cheap material
-mismatched/cheap laminate
-laminating hot/applying stretched lam
