Vinyl that won't curl
bob
Does anyone know of a vinyl that when printed and contour cut with a full bleed can be depended on not to have the edges curl up where the full bleed was cut? Over the years I've tried a number of different products and had some successes and some failures but I don't know of a vinyl that I can be assured won't curl. I've had both good and bad experiences with Avery 1105 lots of initials, 3m high end something or other metallic, Oracal 3751 no initials, and others long forgotten, but none of these can be depended on not to curl.
Is there some secret stash of non-curling vinyl somewhere? Or is it futile to look?
Not sure if this will help, but the proper laminate is supposed to prevent that from happening.
How much time is elapsing from instal time to curling time ??
Is it facing south or close to it ??
I've had some of the cheaper egress vinyls work, but not if it's dark colors.
dale911
President
If you print any vinyl with solvent and don’t let it outgas long enough before cutting, it will curl right off the backing paper. The higher the ink load, the worse it will be. I have even seen this happen with high ink loads of latex. No problems with UV cure inks. If you let it outgas long enough and this happens after lamination, you probably have too much tension on the laminator. The cuts then allow the extra tension in the lam to pull the vinyl up.
SignMeUpGraphics
Super Active Member
It also depends on ink load and drying times. We use a very cheap LG monomeric for labels. We cut through full bleed 320% print all the time. As long as we let it dry 24-48h before cutting, we don't get curling.
CanuckSigns
General formulations 6 mil semi rigid vinyl, guaranteed not to curl, and thick enough to not need laminate for decals and such. It comes in permanent and removable adhesive.
midnightmadman
Old thread but rather than start another I was wondering, if curing happens has anyone come up with a method to keep the vinyl down again permanently?
Boudica
Do you not understand the question?
I understand your question, I was being facetious - hence the "big laugh" emoji.
I don't know of anyway to keep curled edges down short of sticking it on to something, or maybe using transfer tape (overkill, and not even sure that would work). If it's calendared vinyl it may just relax on it's own with some time.
Boudica
Was this not about vinyl that curls after installation...
hah, maybe. I didn't re-read the whole thread, I was thinking this thread was about vinyl curling after cutting it too soon.... I must have been thinking of a different thread.
Sorry everyone. I'll see myself out.
midnightmadman
Thank you. I may try that actually
Like to send you Photo Tex polyester adhesive fabric that you could full bleed contour cut without curls. email me walterjr@phototexgroup.com I can send you a free sample.
