vj-1204 not original Magenta
yonu
ok am needing a bit of help I just pulled my spare vj-1204 out of storage and had planned to convert it over to sublimation ink however in seeing if everything is working all I get on the Magenta slot is not original it doesn't matter whether I use a empth mutho cart which i would think should read ink end or a 3rd party or a bulk smartcard i get not original I have cleaned the contacts on the printer and nothing the firmware is 1.16 any suggestions on what to try?
heyskull
On our old VJ-1604 the card reader pins would get bent when fitting cartridges.
This became such a common occurence I had spare card readers to fit when this happened.
I am guessing this is your problem also.
SC
Johnny Best
Did’nt the 1204 change awhile back where you had to use 3rd party inks because you could not use the Mutoh ecosolvent inks anymore?
yonu
so i actually removed the cartridge bay so i could look at it i cleaned the chip reader, and no change so I am guessing i just need to go ahead and replace the chip reader board?
yonu
Well I replaced the ink chip reader that's in the cartridge slot and I still get the same error not original even if I put in an original cartridge so what are suggestions for what I should check next
is your supplier pirating the cards?
there is a good profit in cutting mutoh out of their end of the transaction.
if it is a "spare"
swap the cartridge set. see what happens
swap the black with one of the other colors, putting wrong colors in 2 slots.
is the firmware version the same on both machines?
yonu
Ok I have tried 2 original cartridges both say not original even one that is empty and a 3rd party it of course says not original. If I swap them and put a black in magenta it takes it and doesn't give error if I put magenta in black slot it takes it and doesn't give error in thoughly confused at this point
