Watch me trace
The Vector Doctor
Chief Bezier Manipulator
Most of you know how to trace but there are some customers that don't quite know what is involved. So I have posted a quicktime movie of a somewhat simple job. Even the veterans might learn something. This was done using Adobe Illustrator CS3 because I prefer the smart guides in CS3 over what Adobe changed in either 4 or 5
I use smart guides and frequently use the weld tool and the minus front or minus back tools to make sure all points align perfectly.
Note: the last letter T did not quite line up on the baseline but that was fixed
http://dl.dropbox.com/u/5144854/vector trace.mov
Warning to those with slow connections: file is 12mb
weaselboogie
yeah way quick! wish i knew illy - looks like the bezier tool is better by far than corel if you know shortcuts etc
maybe you dont know the corel shortcuts...:rolleyes:
Awesome work eric! Amazed at your speed and precision! Sometimes what I'll do is fine similar characters and use them to create the second letter. For example the O, I could trace that then chop it off to make the C. As I'm typing this, I assume that you know this and that you're trying to show the entire process to the customer and not shortcuts. I'll shut up now. :Big Laugh
The Vector Doctor
Yes I do this quite often.
The Vector Doctor
Thanks all for the compliments. If there is anything that you want to see I can probably make a movie when I have the time.
The QT software movie on this was originally 900mb!! I reduced the resolution and resaved. Is the quality ok to see what is going on? I'm on a 23 inch screen
TheSnowman
So THAT'S HOW YOU DO IT! I don't even need to send you anything anymore Eric! J/K...great work as always. I love how fast and perfect you are at it.
The Vector Doctor
That is one reason I posted it, so people could see the quality that goes into each job. It certainly helps having clean art. Plus someone might learn something.
