well lets see if i can actualy make some $ this time
Maverick Signs
did a bunch of painted qoutes for a school a while back and now they want this in their entry. the letters are 15.5" tall so it comes to roughly 4'x20' its about 12' from ground. the last time i cut some vynil for mask
but it blead quite a bit. read somewere ( maybe here ) that if you paint the edges of your mask w/ the original wall color and let it cure, it will
seal the edges and give you a crisp line. anyone tried this? anyway it seems like im off on a lot of my bids and any help would be appricated.
last time i charged 600 for 3 quotes w/ 404 letters im sure that was to low
anyway thanks all. i was thinking $450.00
Techman
8 - 10 bux a sq ft...paint up on ladders is no fun,, use a rolling scaffold that they pay extra for..
But you do what you gotta do..
D
DARLAK
Guest
huh? what?
what iz vynil??
yea that sounds like a good price
Yeah, those little serifs will be a bitch to paint in.... you'll lose half your time on them alone.
What kind of wall is it ?? Inside or outside ?? Brick, sheetrock, block, wood already painted..... ?? .....and what condition is it in ??
Probably use a pounce pattern and hand paint them using a fitch and cutter. The letters look too thin to use a roller anywhere.
We'd be about $800 to $1,000.00 on that based on the wall type and prep time needed.
Good Luck.......​
OldPaint
4x20 = 80 sq ft. so @ $10 sq ft it would be $800.00.
$5.00 sq ft is $400.00......and how you gettin up there?
us old wall painters.....on the ground, with a wall ready for paint.....dont work for less the $5 sq ft.........so you gona go up, for a little more then $5 sq ft?
ALSO....if you gona paint LEARN TO USE A BRUSH to cut an edge......this can be done with a littl practice witha FITCH....brushes used for rough surfaces...or you can do the same WITH A GOOD FOAM BRUSH....just find a wall similar in texture and paint......and play a little AT CUTTIN A STRAIGHT EDGE...really not hard to do....i seen ileagals paintin AUTO ZONE......walls.....if they can iam sure you can.....I CAN, SI CAN, GINO CAN, REX CAN..and were old)))))))
you youngins need to learn this....AINT NO OTHER WAT TO BIG ROUGH SURFACES...
and you CAN MAKE MORE MONEY....IF YOU PAINT IT!!!!!!
Jillbeans
If you're using that font fix the kerning, I'm sure it's just a sample.
Get them to rent a rolling scaffold.
Never heard of the painted mask/wall cover thing but it is cheaper for you to just paint it by hand.
Project it onto the wall and sketch it out with vine charcoal. then paint using a fitch for the outlines and cheap china chip brushes or small foam rollers for the centers.
I just lost out on a wall job for being "too high" so I won't quote a price...but don't do it for only $450!
You could do an easy wet blend on those paw prints to make them look cool.
Love....Jill
Maverick Signs
yea an enginering firm did the layout.
might try and submit somthing to give some
umph to it. but they were pretty proud of
the last ones i did for them. not enough room
for a projector. hows 650.00 this is going through
a painting contractor so there going to want a bump.
OldPaint
SCREW THAT ENGINEERING FIRM...they dont gota paint it!!! use a rounded corner/square corner/or rounded serif.....you will waste more time tryin to get them serifs straight.....and no materr what you do..THEY WONT LOOK STRAIGHT......cause of the rougness of the wall.
$650?????? what the paint contractor got to do with this????
HE PAINTED THE WALL..BIG DEALLLLL....any dummy can paint a wall.....THATS WHY HE WANTS YOU TO PAINT LETTERS...HE CANT!!!!!!!!!!! CHARGE ACCORDINGLY!!!!
