What would you charge
Bradster941
I need to do something similar to this on a 1 ton 2003 Dodge truck, doors only and in one color. Will also have a graphic of a ship. Will be using Oracle 751.
I haven’t seen the truck yet, they are dropping it off this weekend, so am guessing size will be around (W) 32” x (H) 22”.
What would you charge?
Thanks,
Brad. :glasses:
Checkers
Hiya Brad,
I guess it would depend on how accurately the design needs to be reproduced. I would figure a couple of hours there alone.
Then, assuming the truck is reasonably clean, I would estimate at least another 2 hours to deal with the client, clean the doors, size, cut, weed, tape and apply the design to 2 doors. and hope that nothing goes wrong in the process.
If you're using HP cast vinyl, you'll have at least $25 retail value in materials. so, I would figure 4 times your hourly rate if you're efficient and at least $25 or more for materials.
So, to accurately recreate the design I would charge $150 - $200 and an additional $195 to letter 2 doors at the size you mentioned.
Cheers,
Checkers
iSign
I agree with Brian, if you have to match the existing ship, with only the truck door to go from,then I would be over $300. If it was simple one color work from a disc... then I'd be around $200
Bradster941
Thanks everyone. It doesn’t half to match exactly, they said I can do whatever I want. They’re mainly concern that the phone number is big and readable from a distance.
Fred was good enough to point me where to buy the ship that will be used.( Thanks Fred). So it should be pretty much a 1 2 3 job. :thankyou: :U Rock: :thumb:
