Still don't get it. There is no need to have Windows XP, Ever.For the most part, totally true. Serial adapters are totally a thing, and you can get them for almost nothing. Software is where the pain can lie. Sometimes it can be worth rebuilding an XP machine if it means saving a few thousand bucks on a machine that is already on the short list for replacement.
You Should just say: "I do not know reliable way..." because someone does.The Oce Arizona I have runs XP for the control system. No reliable way to go to a newer version. Always edge cases.
you can't always do that.When dealing with hardware that existed for basically one OS generation, drivers are going to be crazy specific. Already made an image of the drive on the Oce for backup sake and will probably convert it to a solid-state HDD for reliability sake. At best, an OS 'upgrade' might be shoe-horning Windows Vista on the thing at a huge hit to reliability (and one could argue that it would be a downgrade). Getting 64-bit drivers would basically be impossible, so would kneecap you on any current OS. Embedded systems be like that.
I am definitely going to scope out the system interface where it talks to the printer. The Scitex printers were fascinating, but the OS seemed to be somewhat custom.
If using an old vinyl cutter or something that just speaks HPGL over a serial connection, the operating system is almost a non-issue as long as you can generate the code and stream it to the port.
What Version of Flexi is it?i have a computer attached to a cutter that runs an old version of flexi. that flexi will NOT run on anything newer than XP. I aint about to pay another subscription just to have it on that one PC that I use sometimes.
Flexi 8. Production manager won't run rightWhat Version of Flexi is it?
Flexi7 can Run on Windows 7 32bit. Issues with Rip/Print on 64bit.
Flexi8 works with no issues on any Windows7 systems.
since. version10.5 can be used on Windows10 or 11 as well.
I run CASmate on Windows 10 32bit computers. Many of my Clients do not want to learn Flexi neither Enroute.
