I have experience with CNC machines both hobby level and DIY (I have built a few of them)
Timing belts are fine they work great the big draw back to them is that if your machine is built heavy duty then you must start slow ramp up to speed and ramp down to stops.
You can make them really fly though on large machines 1800 inches a min no problem.
If you know that you are going to use this machine for light duty such as
signs and very light aluminum then go for it the belt drives will be fine.
If you want to machine aluminum block well then you will need to go to either ball screws or rack and pinion drives.
Dont even think about steel if you get a machine heavy enough at the hobby level it may cut it but it will be very slow and the cuts will be crap (theres a reason why mills are built from cast iron).
Also there is the question of precision do you need it to be accurate and repeatable by .001" belt drives can do this if the machine is built right.
For
Sign work in foam, wood, acrylic, plastic and light aluminum most any cnc will work just pay attention to the accuracy and the repeatability they are the key also most companies will say rapids at 1800" min thats great but all that means is when the machine moves from one place to the other (not while cutting) it will move at 1800" min most of the time you will machine at a fraction of that speed (wood foam etc.. roughlly 100 to 400 ipm) aluminum 100 or less ipm.
Just my 2 cents.
PM me if you want more info I have enough to make your brain hurt.
Edit
Just went and looked at the machine should be capable if you dont do anything hard like aluminum (aluminum sheet like max metal would be ok).
You also have to buy with that the Gecko drive (love those things) the mach software (it reads the code and tells the motors what to do) Cam software (takes your design and makes g-code ie tool paths) so your looking at a ball park of $800 plus the cost of the machine to be able to use it.
Personal note I would buy a 4'X8' cut area machine you will regret it if you dont (unless you have a specific use for the smaller machine).
