All right Folks Let me have it..
Blazingsun
This will be going on a Trailer.
Second question: Whats the going price for something like this installed? it will be printed on oracl 3651 and laminated Size is 4'x8' (2 sides) and back 2'x4'
James Chrimes
Well to be honest I think you are trying to make the design by adding too many bells and whistles, but forgot fundimental functional design. Using a leaning script in an arch always looks a little funky to me. split the two phone numbers below the design on either side of the arch and make what the customer provides bigger. It's great to be able to print all types of kool effects but only if they are relivant. Does the customer work with metal? just my thoughts.
thewood
I would suggest printing this on Oracal 3951 with the 290 lam, which are both cast films. The 3651 is calendered vinyl.
Derf
Reduce the gap in the boards!
I like the wood and house in the back
The metal looks...???? Wrong for the sign.... I would make a brushed gold for the trim and letters in photo shop.
The white text... Ahhhhhhh looks bad
Too much going on
Simplify.. then polish... with a few effects but not a circus
Any way the design is a good start.
I would charge $250 - $500 or $65-$100 per hour for the art set up and then charge for the print as normal
David Snider
Hey Blazin...Check out this http://www.graphicd-signs.com/html/small_business.htm site and see the difference in the way you are approaching you work. There are a lot of things that just don't seem right about your design. Using what Photoshop can do is not always the best approach.
The metal isn't right...the bolts are floating...slanted script on an arch is a no! no! Drop shadow is overdone. I think you might step back and get some design books and read up on what makes and breaks good design.
Hope this helps...not just being critical...I want to help.
OldPaint
wait...there more.....!!!!!! YOU HAVE NO SIGN SKILLS....and your trying to compose a picture......THAT IS A SIGN....now which do you want to do.??????????
you need to lean to make signs, taking text and making it something to draw your attention to...and READ THE INFORMATION!!! you got more stuff goin on in this PICTURE....you might turn it into a movie!!!!!
you got a printer.......now you need to learn about signs....
1. start with WHO, WHAT & HOW TO GET AHOLD of this person.
2. pick some nice fonts!
3. make sure you got a nice CLEAN MESSAGE
4. then add some graphic (if its needed)
5. K.I.S.S.
6. just cause you do all that crap.....is it really needed to get the point across and to make it in a nice design?
6. get mike stevens book on layouts....
go look at dan antonellis work.....
sorry if i said anything you dont like.......happy new year
ChiknNutz
I personally don't think that was called for, but it is your opinion.
Not saying that these are outstanding, but here are some concepts I did for a similar company.
Bigdawg
Just Me
Hey Gerry - just keep working at it. There's a big difference between creating signs and designing for print. I'm still in that learning curve myself and have to step back and give some of my work the squint test. Not trying to speak for Old Paint - he does fine for himself! - but I think that's what he meant when he made his comment about sign skills...
Design-wise I think Derf pretty well nailed it. You have a good start - just too much overkill on the effects. They all compete with each other. I'd lose the cursive in the name and make it a solid color since you have a "pattern" (woodwork) background that competes with it. Gold trim or a dark brown woodtone border would be a nice touch instead of the metal. With all the color your eyes are drawn to the white instead of the main thing you want people to remember - the business name. I like the shape and you should be able to build on this one rather than trashing it and totally starting over.
gtjet
Nice designs Chris, Pearl & I like them a lot.
Gerry,
Can not wait to see what you come up with after all the advise and samples above. Good luck
Techman
Sorry my friend. I think you should start over. You have a lot of time in that design but it just isn't ready for the real world.
First, purchase stevens layout book, Then, purchase Dan Antonelli's books. Then bring the next attempt for critique. I know you will get better news.
Graphixtreme. I wonder why there is machine turned gold in a wood based theme? It turnes the eye away..
OldPaint
i ment what i said...you jumped right past SIGNS & went to PRINTIN pretty PICTURES... without know how to DESIGN & PRODUCE A SIGN!!!! you need more ability to know when to SAY STOP...K.I.S.S. keep it simple stupid!!!!
one you understand what your main objective is..then you can go to some graphics....but you just to much goin on and none is readable.......START OVER with something simpler and you will see a lot more ...with a lot less!!!!!!
Blazingsun
Another go at it
Ok All, I think I got it.. let me know if Im heading in the right direction.
As for OP comments :
"Originally Posted by OldPaint
wait...there more.....!!!!!! YOU HAVE NO SIGN SKILLS...."
I agree with GraphiXtreme this was not called for nore was the "K.I.S.S" Mostly the Last S. But Very Much Understanding The "K.I.S"
But from hanging around here I have learned thats "The OP way"
Any who I have learned some new things and Im always open for learning more..This site is awsome. and full of great people. Even You OP :thumb:
Jon Aston
Hi Gerry.
I'm no designer and can't offer the same sort of "rules of design" suggestions you're getting from the others.
I will say that the stuff you're doing with the paint/wood effects is way-cool...and certainly seems like it communicates something about your client's business, graphically.:thumb:
I think the use of SignGold for the company name detracts from the overall design (and would have to agree that the slanted script on an arc needs to go). If anything, I think a more effective use for the SignGold would be to use it for the words, "General Contracting". There isn't much contrast between the black copy and the "wood" - plus, I think the use of gold for that particular phrase implies "Quality General Contractors".
2 cents from the peanut gallery.
OP sucks.
(Just kiddin' OP)
Bradster941
Yup, I was going to say I can't easily read the name either.
Maybe replace it with a solid color, expand it, and see if that makes it easier to read. Do you really need to put the Corp. in there? If so, then spell it out on the next line, if not, drop it. It's just one more thing to read in a flash.
Also, much as I hate to say it, you might want to try all CAPS for the name as the Grumpy old Man, (oLd pAiNt), often insist upon. :Cool 2:
Blazingsun
For Some Reason when I add the Arc it does that slant thing Why I have No Idea it starts out straight but changes when the arch is added..
Billct2
Critiques should be critical.
And to that end I also agree that you should start the design all over again.
Prioritize the message. Get something that looks good in black and white first.
Then add the accents to enhance the message not hide it.
I too think you need to become more familar with the basics.
Get the recommended books.
ChiknNutz
I'd suggest that you do NOT condense and arch the text - especially condensing it. I would also either remove the other wood effect from the "GENERAL CONTRACTING" line altogether, or make it the same as the one in the background panel (not enough contrast and it makes it too busy). The text in the center gets lost pretty easily. Either remove it from there and place it elsewhere, or give it more contrast (and a bit bigger)...maybe two lines to allow it to be larger? Try it under the phone numbers.
