Am I in the ballpark?
FatCat
Lately, I've been questioning if I've been coming in a little low on some of the larger signs I've been doing. Currently, I have one coming up which I would appreciate some feedback on. *See drawing below
-(2) 8"x8" treated posts - 10' - pyramid cut top w/1" reveal - painted white
-(5) 2"x6" treated rails - 56" - painted white
-(2) 4'x6' MDO panels 1/2", white/dark blue paint & white hp vinyl.
-On-site install
I'm coming up with about $1400-$1500 for this built and installed.
I know there will be some variations with everyone, but am I in the ballpark?
Thanks.
FatCat
Sorry, no not custom routing. Most of the others made around here simply using 2"x2" strips front/back screwed to the 8x8's. However, I'm considering angle brackets for a cleaner look. Any other ideas?
Yes, sign is double faced (2) 4' x 6' MDO panels.
Billct2
I'm in a different ballpark.
I don't like to paint new PT posts, we stain those we can't cover.
Okay, I'm not quite understanding this. If your sign is double sided, then your picture shows the panels must come out from the inside of your post. How will you get any strength for support for the two 4' x 6' panels if they aren't routered in ??
Can you make a quickie bird's eye view of the various planes ?? :thankyou:
FatCat
Sure, hopefully this view from above will help.
SignManiac
How are you planning on attaching the 2"x6"'s to the 8"x8"'s?
Seeing that it's a double face sign. My minimum would be $1,500 and I'd try to up sell the job to $2,500- $3,000 as a dimensional sign.
FatCat
Ah, sorry again - trying to do too much at one time. I just re-read Gino's post.
OK, so most of the existing signs here have been built using rips from 2x material - so it would be a true 1.5" x 1.5" which is screwed to the 8x8 posts and runs the full length of the fence rails on both sides of the fence rails. (See example on left with pink blocks.) The rails are bolted or screwed through the rips.
I was thinking of using either angle iron or joist/framing hangers instead of the 2x rips which I think would look cleaner, and also reduce the risk of any splitting down the road.
Thoughts?
That was my point, also. There won't be any strength in that installation. even if you use 'L' brackets or whatever.... a much better and more aesthetic approach would be to notch the 8" x 8"s out and do it right. Couldn't take much more than an hour or so, if you're using a plunge router.
Anyway, using a better instal there and based on the rest of your information.... I think you're leaving a lot of money on the table. Using this information as a basis we would be closer to about $1,900 to $2,100 installed.
I too, would try to up-sale the entire job.
We're doing a 3' x 5' - 'V' shaped sign with 6" x 6" posts. Installed w/permits...... $4,685.00. No raised lettering, no recessed lettering and no gold leaf. Just two flat signs mounted to posts with some cross pieces and gold paint finials. I might flute the posts, but nothing more.
FatCat
I appreciate the info guys. When using the router method do you typically use any other hardware or glue in the joints or is there sufficient strength as-is?
*Also, the sign regulations around here are VERY strict. This is a hi-end community (think Stepford) and the zoning and architectural review board want all the signs looking the same. Plus, I doubt they'd want to pay extra for a dimensional version.
Again, I appreciate all the advice.
If you'd set the boards in about 1-1/2".... a screw going through the post from both sides into the board and countersunk would be fine. Drill out a larger hole and then put a wooden plug in it. Makes for a very nice finished look and it also appears like a very rugged installation.
As for gluing, try to avoid that. Should you [or anyone else] need to take the sign out for repairs, vandalism or any other unforeseen problem.... you won't get them out without a big mess.
