Happens with IG(insulated glass) panels. There are calcs used by window tinters to make sure they don't have issues. A high school not far from me went with the low bid tinter after my buddy the pro said what you want to do won't work. Long story short most of the windows that were tinted shattered. My buddy had a good laugh. Perfect example of not knowing the scope of the job and all the variables.
I see vinyl and tint as the same. YMMV
I've heard of it happening, especially when its full coverage. If you are covering less than 50% of the window you should be good but don't take my word for it.
You've actually heard of it, wow. And I've actually seen a quarter appear out of the nose of a small boy.
Glass is some pretty tough stuff and a little heat absorbed by some vinyl stuck to it is not likely to cause it to break. If it does then I would strongly suspect that there was something wrong with the glass.
I still dont see how vinyl or tint would break glass. It wouldnt make a difference if it was IG or not. The outside pane of IG glass would still absorb the heat evenly on that panel. The middle is just a thermal break but the individual glass by itself will still absorb heat evenly, it just doesnt project it as much to the other pane.
In curtain wall construction, mechanical rooms as well well as other areas that need to be hidden, there is a solid block out opaque coating on the glass edge to edge. Glass in cars and equipment has blackout coatings too in partial areas. Look at the frameless windows in buses, they have black blockouts that hide the bus frame. I do understand not using a heat gun or torch on glass since it is a rapid concentrated heat that the glass can not distribute fast enough which causes uneven heating and breaks it. With vinyl, it will be a slow warmup and whether it is partial or complete, the glass itself will evenly distribute the heat faster than the partial area can warm a concentrated section.
Heat doesn't break glass, in fact glass can withstand any amount of heat. It's the by-product of applied warmth (absorbing heat from a heat-collecting material in contact with the glass) which is expansion -- especially uneven expansion or expansion beyond it's container (frame).
And it doesn't even need to be a lot of heat to expand a pane of glass beyond the limits of say, a tight-fitting frame in the case of compete coverage or tint.
And in the case of just lettering -- well, imagine a big 4' letter S on a large pane. and the sun comes around the corner on a cool day... what's going to happen? Well, the glass covered by the vinyl in the shape of an S is suddenly going to start absorbing heat and expanding where the glass surrounding the letter is not absorbing direct heat from the sun and not expanding. Once a crtitical temperature differential is reached that pane is going to shatter from the uneven strain. And the temperature of the glass in its warmest spot need not even be that hot. Like, say, on a cold winter day in Calgary.
We all know better than to use a heat gun on glass -- its the same principle.
Heat doesn't break glass, in fact glass can withstand any amount of heat. It's the by-product of applied warmth (absorbing heat from a heat-collecting material in contact with the glass) which is expansion -- namely uneven expansion or expansion beyond it's container (frame).
Well then Dr. Science, according to my sources plate glass will expand somewhere around 0.0008" per linear inch per 100 degrees temperature rise. Not the rate of expansion that leads to shattering one should think.
Has anyone, anyone at all, ever actually hands on, not tales from a friend of a friend, broken or witnessed the breaking of a pane a pane of glass via this type of heating? Not that you couldn't be putting out the truth, the whole truth, and nothing but the truth but this certainly smells of urban legend.
A heat gun [or a torch] most certainly is not the same principle.
Before you pose that a light absorbing coating over a glass panel can cause the glass to break because of expansion you might want to familiarize yourself with the coefficient of thermal expansion for glass, which compared to other materials is quite low. If memory serves plain old plate glass expands a few ten-thousandths of an inch per foot per 100 degrees of temperature. Hardly the stuff of shattered glass.
There may be something more to coating just a portion of the glass. Then there would be uneven heating that might do something. Or it might not. One would have to compare the light absorption properties of the coating to that of the glass itself.
