Box truck pricing
ChiknNutz
Just looking for a little feedback every once in a while on pricing. This project consists of vectorizing the client's existing logo from JPG, PLC logos (print/laminate/cut) for the sides and rear, then applying black HiPerf to same. The sides of the truck are 76" x 168", the rear is 87" wide x 71" tall. Pretty simple overall, but just looking for some feedback. Thanks.
Pro Image
Just curious Chris why not do the whole thing in HP? Is it the color around the valve that will make you want to print it?
If I was going all HP vinyl.......or Print and HP I would charge around 800.00 or so...........
ChiknNutz
I've priced it out my normal way, and the whole package is coming in at a touch over $1300 (+ tax). My gut feeling is that this is on the high side, that's why I'm looking for some opinions of others. For me, my break-even point on print vs cut vinyl is usually just 2 or 3 colors, so that is why I chose to print, plus it's an easier install.
For that little bit of copy, I too, think $1,300. is a little high. Regardless of digital print or not, the total job looks more like about $700 to $800. Sometimes you must look at the whole thing and justify your price structure. No offense, but that just doesn’t ring anywhere near $1,000 to me… even with rivets to go over.
cdiesel
I totally agree with Gino. Per our normal pricing, we'd be at $1080 for the whole thing. I'd include the vectorizing, as it would only cost about $12 to have it traced. But, I don't think I'd shoot it at $1080. Knock about 20% off and I think you're in the ball park.
asignstop
I still don't understand why you would print and cut the plumbing spicket, you mentioned your "cut off" point is 2 colors, but couldn't this logo be done in straight black and let the color of the vehicle show through for the white areas? Wouldn't this end up looking better - than having two different color whites? or am I mistaken and that color a light grey?
iSign
I'd be over $1000 just to do banners equal to the sq. ft. of that job.
If I couldn't get over $1000 on that job, I'd pass it up. But, that's based on pricing in my area. I ask $7 per sq. ft. on single color banners w/o logos. I count about 150 sq. ft. of coverage on that job. I'd be looking for at least the $1300+ that you mentioned.
I'd also tell them it would look better to reduce the size of everything at least 10% It's too crowded in my opinion.
Mike Paul
Super Active Member
On this particular job:
I'd say $900 is a steal. $1,100 seems about right... 400+400+300
Vectorizing the logo is a piece of cake and would only take about ten minutes; so I'd tell the customer I was throwing that in for free as a courtesy which helps sell the job and keeps the lettering value higher on the next truck.
I'd print the oval logo so I only had to deal with the rivets once.:thumb:
OldPaint
182 sq ft.....simple $10 sq ft price is $1820. addtional art work and laminate............use youre regular rate.....
ok i posted my price BEFORE READING PRIOR POSTS.
by the looks of the trucj you are covering at least 5 FEET TALL & A FULL 14 FEET. 5X14=70 X 2=140sq ft. rear door is 6 FEET X 7 FEET of coverage. so another 42 sq ft. 140+42=182 SQ FT. i priced at $10 sq ft.
at $5 sq ft it would be $910.00 at $7.50 sq ft it would be $1365.00.
sq ft pricing makes it simple......
only differance between a truck a 4'x10' sheet of alum..IS THE TRUCK GOT WHEELS.... a sq ft of printed/lettered space is the same on either one!!!!!
cartoad
Chris,
We just bid on a box truck Thursday very simililar layout and for us on the other side of the state we came in at just under $800.00. I would think your area would be higher. Good luck.
Hal
iSign
OK, Op, I'll take it!!
...now about that other 2/3 of each side of my truck you just charged me for... I want "Gone with the Wind" cut & applied in 1/2" old english!
Jillbeans
Last time I did a box truck, I charged $1000 for a mix of paint and HP vynull.
That was about 2 years ago.
Today I'd charge $1200.
Love....Jill
Checkers
Hey Chris,
Here's a smarta$$ reply...
Since you publish sign estimating software, should you really be asking this question? :smile:
In New Jersey, I was getting $1000 for work like this 10 years ago. Now I would estimate $1,500 to start, because it's "worth" much more. I would use all HP vinyl too.
You have to remember a truck like this advertising, not a commodity or "by the pound" generic product. I would suggest that the client spend at least $2,500 for some real digital printing and do the job right. Anything less may work, but he would see a much higher return on his investment if he did it right.
Checkers
OldPaint
OTHER 2/3'S?????????????????
i dont see what you are sayin.......@ $7.50 sq ft for $182 sq ft $1365 is a decent price....and you guys are alway tellin me i DONT CHARGE ENOUGH?????????
iSign
wel, I didn't do the math yesterday, but I was guessing you came up with the square footage of the entire sides... rather then just the graphics down the middle. The entire 2 sides PLUS the back is a bit higher... but I'm just givin' ya grief. On a truck, I wouldn't tell the client I used a sq. ft. formula... but I think your price is good OP!
