Engine Turn Bling Bling
slappy
1st- besides Sign Gold and Quick Gold, is there anyone else that makes this?? Is there imitation also?
2nd- And what's the process to cutting and installing it? Should it be applied dry or can it be applied wet? What blade for cutting?
3rd- I need to add black also, but do not have a printer? Can i just apply black vinyl?
4th- Is regular transfer tape like maintape or rtape 8075 fine to use on the gold?
5th- What lam do you use? I heard you have to lam it? Can i apply that wet?
Sorry so many questions, i've never dealt with gold before and interested in making a nice memorial sign to learn.
Lotsa manufacturers do. Just pick one.
Dry and a little extra down force.
Use the black as the first layer and the gold on top.
Any application tape will basically work.
We don't laminate it at all.
It's a snap to work with.
Pat Whatley
What Gino said. I like the Schein Holographics film from Sign Warehouse. They recently changed it so that it's thicker. Cuts the same as always but weeds like it was regular vinyl. Absolutely beautiful stuff to work with. DO NOT USE IT OUTDOORS. Sunlight kills the color....it will fade to dull silver in six months. Indoors I've got doors I did five years ago that look like new. Unfortunately, from what I've experienced, if you want outdoor gold you're gonna have to use real gold.
SignManiac
I've looked at a couple of signs I did fifteen years ago in sign gold and the stuff just seems to last forever...
Pat Whatley
Why would edge sealing matter for fading? It's gold....a mineral. I thought the edge sealing was just to keep the laminate from peeling.
visual800
not necessarily. Ive clearcoated imitation gold and its lasted outside for several years. you do not need real gold
slappy
Thanks everyone for the responses. I want it to last outside cause it will be a memorial on a vehicle, so 22k is the way to go.
And i'm just finding out sign gold is quick sign gold from my research. I cannot find anyone else that makes the real gold.
Then I learned there is 22k and 23.5k and one is yellower then the other, but the lady that answered the phone couldn't say which is which.... but i did request samples.
Then Fellers and Glantz only stock the 22K, so i'm going to assume that is the more popular of the colors..
Also, she told me to edge seal it... But with what? Seal it pen or 3M edge sealer??? What are you all using??
Also, she said it has a clear already on it when i asked about laminating it....
BTW, Any MM print on this?
Any other suggestions for me too are appreciated Thanks:smile:
letterman7
I get my printable SignGold from Beacon. Usually ships within a day to me. I've never had to edge seal SG, but I do laminate the prints. Done more than several fire apparatus with no failures yet (knock wood).
Billct2
From what I understand SignGold no longer has a clear laminate, it is all thermal printable.
We use frog juice, and seal-it pens, but for real longevity apply clear cast vinyl with an 1/8" overlap.
Mike Paul
Super Active Member
SignGold has always been composed of a tough Tedlar laminate and built from the underside. They also have a thermal printable version...
Malkin
When I use SignGold I always design in an outline that I then use to trap over the edge of the gold (just like you would with translucents) The edges do tend to brown up and lift a bit of you don't, but when you do, it will last and last. 10 years and counting.....
Billct2
Unless I was misinformed this is no longer the case. All their products are now thermal printable, you can't thermal print on tedlar.
