Help
Lightbulb88
Like this?
Jim Hancock
Old School Technician
Correct on the ribbon positions now. However, the power issue obviously needs to be fixed first. This is starting to get into electronics technician level troubleshooting with a multimeter and possibly an oscilloscope and the ability to read schematics. You may want to consider reaching out to Damon, as I understand he has the ability to troubleshoot the mainboard beyond the output transistors. There can be multiple reasons for the power not coming on, but it starts with a signal from the control panel to the mainboard. As the last issue was issues with the printhead which is also connected to the mainboard, in my opinion, that's where to start. It's possible whatever was causing the printhead to print strangely finally went out and won't let the printer power up.
Lightbulb88
I just ordered more ribbons, I had replaced them before. After all the movement I want to make sure they are percent good. I would be nice if the power issue is the ribbons... I will post again once they arrive. Thanks again!
Zoogee World
One question, did you power it on after you did that wrong crisscross of the ribbons? If so, my guess is that you blew something. Those ribbon cables shouldn't stop it from turning on unless it fried something when you put power through them incorrectly.
