Installing 4 x 8 outdoor sign
PaPrinter
Looking for the proper way to install a 4' x 8' sign. It will be mounted to a cinder block wall. Using 1/8" Dibond or a similar aluminum composite substrate, is 1/8 thick enough? I'm concerned about expansion and contraction here in Pennsylvania. Also wind loading. Will normal standoffs around the perimeter be ok?
reQ
When i do any dibond signs install right against the wall i would always make a simple frame from treated 2x4 & stain it black. That way sign will be raised a bit from the wall. If you screw it right flat, it will look cheap.
Moze
Precision Sign Services
Masonry screws with washers, paint to match. A few dabs of Lexel.
Don't know where you are in Pennsylvania, but around here, if you flush mount a sign to a wall, there's generally no wind load/sheer involved.
There are several correct ways to mount a sign to a wall. If you're gonna use thin 1/8" stuff, ya need to build a frame from either wood or metal, preferably aluminum. Mount the sign to that. If you use thicker material, you can use french cleats... or a frame. Depends on what the customers wants. Some customers don't wanna see any fasteners showing, so you might build a top and bottom holder, bend the lip and screw down from the top and up on the bottom and the same to the sides. Stand offs for something as flimsy as 1/8" I doubt would work. Not saying it won't, but doesn't sound feasible.
boxerbay
instead of dibond use .040 aluminum cheaper and tapcon with washers screwed directly in to the wall.
PaPrinter
This is our first large outdoor sign. I want to make it look decent without spending too much, make it last and try to make it look professional. I'm thinking some kind of frame to get it away from the wall. I'm very new to this.
Lind SignSpring
You could always give our system a look :)
attachment.php
  • LindSignSpring 101(BannerSpring BannerFrame) 5-16-16.pdf
Billct2
I was being facetious.... An .040 aluminum panel screwed to a wall generally looks cheap, all wavy and pocked where fastened. I would do a 3mm ACM on an aluminum tube frame and clips to fasten, add a nice raised border to make it look even better.
petepaz
1" aluminum tube frame mounted to the building with L brackets or angle aluminum, screw the sign to the frame then i get decorative molding from the carpet department and mount that to the edges to give it a finished look
PaPrinter
I do like this. What kind of decorative molding are we talking about? Like an L shape? And the tubing, were they attached 1 by 1 to the wall or were they secured together?
petepaz
i use L aluminum brackets (angle iron or aluminum brackets from lowes or home depot) get the ones with holes. i screw that to the inside of the frame and then screw that to the building with screws and washers appropriate for the building material. then screw the sign to the frame and yes L shaped molding. basically what they use for stairs. some places only have 8ft lengths but you can get 10 and 12ft sections. if they don't have the color i need i spray paint it. then screw that in to the frame from the outside edges so it' not so visible and depending on where it's going i usually spray the screws the same color of the molding.
PaPrinter
Great! Thanks! Where do you get the braces from?
Pat Whatley
Mount the sign to the frame with exterior VHB tape and you won't have fugly screws sticking all over the sign face.
reQ
Okay... it might be just me, but i would never in my life hang 4x8 dibond sign outside using double sided tape.
ams
1/4" would be better to prevent warping. Put in four lead anchors in the corners and drill in. You could also put one in the 4' middle of the top and bottom to support the middle.
Sounds like overkill, but it's up to code and cannot fall down.
J Hill Designs
same.
I also don't go as heavy duty as lead anchors with a lightweight dibond sign
i've used 1.5" angle aluminum glued to sign with LORDS (and a few countersunk screws for good measure) then clips on wall
