Logo for a bar...
They wanted something more hip and modern
Hi guys, thanks for the great responses. That was my feeling too. We're updating their logo because it used to look sort of like a confederate flag. They had this font but thought it didn't suite the new backround. I personally liked it, what do you guys think? It's not an irish pub, they have bands, once a month they have peelers, Rock paper sciccors contests...fun stuff...its a young to old crowd, pretty diverse...Here's what I was wanting to do for them, keep the same font as before but update the backround.
Edit - The Luckys name is from a local beer called lucky...
Marlene
extend the people background out a little as everthing is all the middle of the sign and the edges are blank and it will look better. Much nicer font.
Better. Still electrifying........
Would you please explain again how this thing is going to be lit. You used quite a few terms and I'm confused why and how this is going to be backlit. Certain effects might not have the same results with some of the methods you mentioned earlier.
You know, I've tried playing around with having more people in there but it just doesn't seem to turn out as good as when they are just behind them.. I tryed filling the side space with silhouettes of drinks up the sides but it just looks tacky...
Jillbeans
I prefer the script but would prefer a better script even more. The one you chose is too wedding-invitey.
Look for something ballsier/beefier.
I do like the colors a lot.
Altho to me Lucky's implies Irish/Green.
Love....Jill
Its a back lit sign box, with plexi face...The white would be the plexi showing through, and the light blue would be tranlucent. Everything else will be high performance.
Okay, that's what I thought you said.
Have you ever used this combination before on an electric face ??
Other than a few light colors..... it's all gonna pretty much turn black as soon as the lights go on.
Jillbeans
Here's a suggestion using a different script.
The colors could easily be changed. I used a celtic knot in there for some reason.
It kind of ended up lookling like a cow skull!
One tip I would like to give you is about using apostrope "s" endings, not a grammatical tip but a script tip.
When typing in the script, I would do it like this:
Luckys'
Then I break it apart, weld the lettering, and move the apostrophe to the proper spot. This makes the script have a nicer flow.
Love....Jill
PS
As Gino mentioned, on a lit sign you must use translucent.
They really aren't going for the celtic look at all. They've got mostly redish lighting and a wood look on the inside. What do you think of this new font?
It's geigh and overused. Might be new to you, but it's not at all on the street. Looks like a beefed up 'Commercial Script'.
Add another person to each side and call it a day.
:Oops: Side Note: Jill, I wasn't describing your font, but the OP's other choice.​
I'm still a little curious as to why you're worrying about color. Most backlit signs are on almost all of the time. In the summer they might be off during the bright sunlight hours, but this is what the majority of people are going to see when this configuration is turned on.
Now, that's not bad, but why are you purposely taking this down to about a 10% visibility factor ??
