Logo Help
uneedasign
Trying to come up with my own logo seems to be the hardest thing to do. Does any of these logo attempts look worth continuing with?
Jim Schneck
They all look so stretched out vertically. Try some condensed typefaces.
At first glance….i thought the graphic in 2 & 3 was a roll of toilet paper or paper towels.
Like Doug said, 3 is the strongest. Keep working it.
Jim
Marlene
I like 3 the best too. I'm also with Jim on the name is so long, it needs to be brought in some so it doesn't look like one big line of letters. The upper/lower case helped break it up some so I wouldn't go with all upper even with a condensed font.
Master's Touch
#3 gets my vote too, but what if you made the "L" icon a warm grey instead of Orange? I think if it were neutral it wouldn't be so overwhelming...
Jon Aston
How much of a hurry are you in to get this done?
My reason for asking is that I think you should spend some more time thinking about what your "identity" is, before you try to represent it visually. Your identity should reflect the value you offer target customers and what sets you apart from the dozens of other signshops in your area.
So...
...How do you create value for your target customers?
...What sets you apart from your competitors?
My guess is that everyone is leaning toward #3 (me too, by the way), because the first several attempts are too literal - but they also don't begin to answer the questions above. They say "Langenwalter - We apply vinyl", or "Langenwalter - We cut vinyl"...and they really only say it to sign people (not your target market, I presume). #3 suggests expertise to me...knowing how letters (and possibly communication) are formed.
Finally - as I've been typing this - I can't help but think that your branding (visual identity is only one element) should play on your unique and memorable name. Ie. "Langenwalter - the name you'll remember for results" (or whatever you want to associate...quality, service, satisfaction, etc).
Spend some time with what you want to communicate and I think the logo design will become easier.
Good luck.
vid
Nice illustration quality to your graphics. Like the rest, I'm with the bottom one. The graphic is an easy read and makes more sense to the non-sign folks. Strong choice in fonts, too.
Legibility in the name is the issue. If you use the wider fonts, try a darker color so that it contrasts with the background more.
great start.
Colin
I can't tell what the graphic element is on the middle two - it looks like a hot water tank.
With the bottom one, try your name in a more condensed font like Impact or something, and change the graphic element to 50% black ( a medium grey).
cowiefr
Nice Work
I like all of your work. The rolls I assume are vinyl. This is something my customers rarely see so I don't know how they would associate your logo with a sign business. For advertising 'punch', my pick is the bottom one as well. I would also change the harsh black around the text to a thinner white then medium gray double outline with a slight drop shadow and apply the gray as well to the radius ring thingies on the 'L' logo. Another thing I would try is expanding the smaller text at the bottom to match the width of the main business name text.
wildside
the top one looks good on your new version.
keep in mind the useability and function of the logo, the bottom one is long and short, meaning to get the height good enough to read from a distance the length is god awful
think about the logo on a truck door, then on a 4ftX4ft lit sign, then ask yourself if it looks odd
the only thing i would think is if you do any kind of crane work, to maybe incorporate the bottom of the "g" into more of a crane hook with sign to the left and service to the right of it
my two cents, i think your on the right track though
uneedasign
Here are some revisions using Colin's Advice. I really like what Colin said about the gray L. Do any of these look good, or should I run with Colin's Example?
Colin
I would go with Colin's advice.......he's awesome. And given the inherent value of a properly designed logo, I would offer him some compensation for his time & input.
Colin
Seriously though, on your last example, the lettering and outline(s) are much too close in color value, making it look like a blob and killing legibility. A lighter outline should illuminate the darker lettering, or, a darker outline should not have a white space between it and the lettering, and encapsulate and enhance (punch out) the lettering.
Also, make ONE thing be dominant in ANY sign/layout/logo. If two or more things are yelling "look at me" it doesn't work. Imagine an orchestra where all of the instruments are playing LOUD. It would be an aweful noise. Some instruments MUST play quietly in order for the music to be pleasing to our ears. Likewise, on a visual level, some elements ought to be less dominant.
Billct2
I don't think any of the otlines work, the white space between letter and outline just looks like poor registration
