low humidity/ static electricity issue with Roland TRuvis VG2 540
Mr. Signboy
I used to have similar problems with my VG2 and I’m in the PNW, plenty humid here most of the time.
Mine wasn’t that consistent with bands though, some days it would print ok and some days it would look like that, other times it would print fine and put a band in the middle of a large print. Unfortunately I replaced the machine before I ever figured out what it was.
if you don't have a kitchen (stove) at that location, buy, or borrow a hotplate, put on a large pot of water and let it boil away AT LEAST TWICE
for a small house you ideally want to add 5 gallons of water and 10 gallons a day doesn't hurt, until the humidity stabilizes
we weren't keeping up at home (top floor never does) but a 5 gallon stock pot of water boiling away solved that issue
you stop just before you get condensation on the windows
Mr. Signboy
are you misting your subtrates with 91% alcohol then wiping with a microfiber cloth?
we had quite a bit of trouble last year, because i was using alcohol wipes (i love them for cleaning the printer)
then someone told me to mist the substrate, wipe with microfiber and now we never have a problem
i had the bad habit of the alcohol wipes for decades (i still clean the lower roller of my laminators with those)
Do you wipe off the beginning of the roll or the entire time it’s printing?
beginning of roll should be ALWAYS (dust and debris can cost you a printhead)
we often had trouble with substrates being too static filled, until someone suggested misting and wiping with microfiber
this pretty much solved our issues for lamination (and they were horrible)
i would think this would be worth a try
Mr. Signboy
I agree, for some reason when I read your post I imagined someone wiping the media through the entire print lol.
a couple friends in the business actually do that. one has two employees who stand and mist and wipe and one who "swiffers" just ahead of the laminator
so i probably did write that, because that is what they do...
Jeff grossman
Living the dream
Don't hate , it works - many years ago when visiting a buddy's shop he had this on his printers / plotters for static .
**MUST BE GROUNDED !!** I laughed because it was June and he had X-MAS tinsel on his machines but he had no static . I've be doing it ever since on mine . I have one grounded to a UPS the others to a grounding rod . "cheap fix for a major problem" he would say
but EVERY CONNECTION IN THE USA, ACCORDING TO CODE, has been grounded since 1970
grounding is good, and necessary but not really applicable to what is going on here.
if you have ungrounded outlets, ground them, but that does not provide the kind of protection we are talking about
Jeff grossman
Living the dream
agree
the method above ( x-mas tinsel ) only reduces the static created from the vinyl traveling not the machine itself ( so many plastic parts now a days ) -
Jeff grossman
Living the dream
I almost bought one of those "anti static guns" that might be just the thing for your problem.
I've done that , I have an old static gun for vinyl LP'S ( realistic discotron electronic static eliminator )
I use it mostly for static cling and doing photo positives for a few silk screeners
ebay has many starting at $65. to thousands
jeff,
i have never used one of those, but i was going to buy one
from your experience, do they work?
i am sure it is not a technology the chinese can copy for $65
the wife bought me a fleese jacket. there were so many sparks coming from my fingers, it looked like a highlander tv series episode
engineers will tell you, if you can see a spark, you are generating 2000 volts (very low microcurrent, of course) so it is not surprising that 5 volt electronics get damaged by it
